Cassius Posted May 7, 2018 Share Posted May 7, 2018 Hello guys, I have not posted here for quite a while but need some input. I have a 3.0R spec B 6MT (BLE) and was looking for a power steering pump and found a place that sells refurbished ones. But they state that it will work for the BL5/BP5 model version. Would it work for my model? My gut tells me yes but I am just being cautious before buying it. Any input would be appreciated. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 7, 2018 Share Posted May 7, 2018 At the top of the very first forum is a sticky for opposed forces look there 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
relative4 Posted May 7, 2018 Share Posted May 7, 2018 You can get the part number from parts.subaru.com and make sure it matches that. Link to comment Share on other sites More sharing options...
fame4dame268 Posted May 10, 2018 Share Posted May 10, 2018 Hello guys, I have not posted here for quite a while but need some input. I have a 3.0R spec B 6MT (BLE) and was looking for a power steering pump and found a place that sells refurbished ones. But they state that it will work for the BL5/BP5 model version. Would it work for my model? My gut tells me yes but I am just being cautious before buying it. Any input would be appreciated.I had similar problem with my 3.0. The PS pump for the bp5 or the 2.4 won't work the width for the pulley is bit smaller than that of the 3.0 Sent from my DIGICEL DL910 using Tapatalk Link to comment Share on other sites More sharing options...
Cassius Posted May 11, 2018 Author Share Posted May 11, 2018 I had similar problem with my 3.0. The PS pump for the bp5 or the 2.4 won't work the width for the pulley is bit smaller than that of the 3.0 Sent from my DIGICEL DL910 using Tapatalk Ok, so I guess my options are limited to buying a new pump or seeing if I can find a place that sells refurbished ones specifically for the 3.0. Thank you for that bit of info. Link to comment Share on other sites More sharing options...
