08SpecB_DE Posted May 7, 2018 Share Posted May 7, 2018 Hey guys, does anyone know factory ride height for the spec b? My rear is sagging a little over an inch in the back and I'm wondering if new springs will suffice or if I'll need spacers as well, to even out the ride height. I thought about just buying spacers but I'm not fond of going over 1/2" to achieve what I want. Link to comment Share on other sites More sharing options...
bdcvg Posted May 8, 2018 Share Posted May 8, 2018 Those #'s are in the vacation pics link around here somewhere. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted May 9, 2018 Author Share Posted May 9, 2018 OK thanks Link to comment Share on other sites More sharing options...
RustyRuu Posted May 13, 2018 Share Posted May 13, 2018 so it's just a thought but, what is your rear camber at? and have you replaced anything in the rear. I have seen the rear upper-ist control arm (the one with the bump stop) bushings fail in the rear in a couple legacy chassis and it causes excessive camber (like over 2 degrees negative) and a saggy butt, just something to look into that new springs may only band-aid. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted May 13, 2018 Author Share Posted May 13, 2018 Rear camber is perfect. The rear has been saggy for quite some time now. I replaced the Bilsteins and mounts less than a year ago so I know they are good. I pass by other Legacys all the time and they sit fairly level compared to mine. I'll double check the rest of the suspension anyways. Link to comment Share on other sites More sharing options...
