Dreprince Posted May 2, 2018 Share Posted May 2, 2018 Can anybody confirm if the BOVs that fit the 15-17 WRX will fit the fifth gen Legacy. For eg. The Turbo XS Hybrid BOV Link to comment Share on other sites More sharing options...
FLlegacy Posted May 2, 2018 Share Posted May 2, 2018 If it is specifically for the wrx, you will need to get a hose adapter since our hoses are both 34mm, where the wrx is smaller on one end. Link to comment Share on other sites More sharing options...
Dreprince Posted May 2, 2018 Author Share Posted May 2, 2018 Oh ok cool....are they're any other good BOVs for the 5th gen legacy? Apart from GFB bovs? Link to comment Share on other sites More sharing options...
Scubaboo Posted May 2, 2018 Share Posted May 2, 2018 Ooops, wrong info removed. Link to comment Share on other sites More sharing options...
Dreprince Posted May 3, 2018 Author Share Posted May 3, 2018 Grimmspeed with the adapter. Thanks to Gteaser for posting this info up in one of the threads here. http://www.grimmspeed.com/electronic-boost-control-solenoid-3-port-solenoid-only-2015-wrx-fa20-2010-2012-lgt/ http://www.grimmspeed.com/turbo-inlet-adapter-2015-wrx-fa20-2010-2012-lgt/ Thanks for the reply....but neither of these links are for Blow off Valves Link to comment Share on other sites More sharing options...
GTEASER Posted May 3, 2018 Share Posted May 3, 2018 Oh ok cool....are they're any other good BOVs for the 5th gen legacy? Apart from GFB bovs?Turbosmart makes their Kompact line as well as their Dual Port line that both fit our cars without modification. I believe our fitment is the same as Mazda, 34mm in and 34mm out hose fitting. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Stapp's Law: “The universal aptitude for ineptitude makes any human accomplishment an incredible miracle.” "Simple incompetence is a far more sinister force in the world than evil intent." Link to comment Share on other sites More sharing options...
Scubaboo Posted May 3, 2018 Share Posted May 3, 2018 Thanks for the reply....but neither of these links are for Blow off Valves Holy crap yeah that was stupid of me, those are for boost control solenoids. Link to comment Share on other sites More sharing options...
Scubaboo Posted May 3, 2018 Share Posted May 3, 2018 I was reading the sticky and came across this. Just as mentioned by Gteaser it looks like Turbosmart make some that fit. Ok, to make up for my wrong post earlier - From ChrisCrash in the "what parts fit the 5th gen sticky": The only aftermarket BPV that fits on our cars in the stock location is the Turbosmart Kompact 34mm unit here. http://www.turbosmartusa.com/product...-universal-fit If you have a Racer-X charge pipe, it relocates the BPV onto the charge pipe from the stock location and you can use any BPV that fits the 08+ WRX and 05-09 LGT. Link to comment Share on other sites More sharing options...
Shadow_419 Posted May 3, 2018 Share Posted May 3, 2018 Oh ok cool....are they're any other good BOVs for the 5th gen legacy? Apart from GFB bovs? I'm running the Boomba WRX bpv. The hose adapter is really super simple and I wouldn't rule out good bpv with 15-17 wrx fitment Link to comment Share on other sites More sharing options...
Dreprince Posted May 4, 2018 Author Share Posted May 4, 2018 I'm running the Boomba WRX bpv. The hose adapter is really super simple and I wouldn't rule out good bpv with 15-17 wrx fitment Is it Audible? What hose adapter should I be looking for any eBay links? And sound clips? Link to comment Share on other sites More sharing options...
FLlegacy Posted May 4, 2018 Share Posted May 4, 2018 Its technically a short piece of silicone hose made for the correct nipple size for the wrx fitment. So if you buy a wrx bypass valve, (not blow off valve<---requires tuning unless you run it semi open and monitor your tune)...anyway if you go with the wrx one just go down to your local parts store and get a piece of hose small enough to fit over the bpv fitting and large enough to fit snug inside of the factory fitting. If you just want noise, consider sourcing a racerx charge pipe it places the valve up on the engine where it would be easier to hear with a 50/50 valve. Link to comment Share on other sites More sharing options...
Shadow_419 Posted May 4, 2018 Share Posted May 4, 2018 I can't hear mine really from inside the car. Sound wasn't what I was after though when I replaced the factory one. If sound is what you're looking for, a 50/50 or adjustable bov is what you'd likely want. Relocation like FLlegacy mentioned definitely will help. Link to comment Share on other sites More sharing options...
Becks1818 Posted May 7, 2018 Share Posted May 7, 2018 I have the Turbo smart dual port BPV and have it 50/50. Its really loud. Link to comment Share on other sites More sharing options...
Dreprince Posted May 8, 2018 Author Share Posted May 8, 2018 I have the Turbo smart dual port BPV and have it 50/50. Its really loud. Did you have to retune after install? ...How does it run on the 50/50 setting....Can u state the model number? Link to comment Share on other sites More sharing options...
