18 legacy 2.5i / Where is my ACC fuse??
buying DRL.. wondering if theres an acc fuse to run it on.. or which fuse for the head lights.. im fine if they run as DRL but id like them to turn on when my head lights turn on.. but on the manual i see each light on a seperate fuse.. suggestions?
can i just attach it to 5 15A H/L LO RH ?? with an extra 15a fuse..?
5 15A H/L LO RH
6 15A H/L LO LH
7 10A H/L HI RH
8 10A H/L HI LH
complete list is below
1 7.5A HORN RH
2 7.5A HORN LH
3 10A ILLUMI
4 10A TAIL
5 15A H/L LO RH
6 15A H/L LO LH
7 10A H/L HI RH
8 10A H/L HI LH
9 7.5A DCM
10 15A D/L
11 Empty
12 Empty*1
7.5A ALT-S*2
13 20A FUEL
14 15A HAZARD
15 30A IG2
16 7.5A PU B/UP
17 7.5A OBD
18 Empty
19 Empty
20 20A*1
25A*2 O2 HTR
21 15A E/G2
22 15A ETC
23 15A E/G1
24 15A AVCS
25 15A INJ
26 7.5A CVT SSR
27 20A TCU
28 Empty
29 30A BACKUP
30 7.5A
Empty*2 ACTGS*1
31 25A
Empty*2 SUB FAN*1
32 25A
Empty*2 MAIN FAN*1
33 30A ABS SOL
34 20A AUDIO
35 25A R.DEF
36 15A BLOWER
37 15A BLOWER
38 10A F.FOG RH
39 10A F.FOG LH
40 Empty
41 15A STRG/H
42 15A R.WIPER
43 15A F.WASH
44 30A F.WIPER
45 Empty
Finding an ACC fuse is simple. Take a volt meter and place the ground probe on a bolt that gives a good ground and then touch the RED meter lead to each fuse to see what gives you a positive reading and what fuses do not. Once you find one that is not "hot" when the car is off...then turn the car on and see if that fuse now becomes "hot" and shows 12-13.5VDC. There are several fuses in your car that will meet your requirements. Fuse 34, 38-39 and 42-44 should be dead until the IGN is switched on. You should also be able to use the headlight fuses as well. In the end, you need to make sure you are not overloading the circuits and blowing fuses. Use fuse taps for a clean and safe install.
https://www.amazon.com/gp/product/B01DYQM6EO/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
thanks for the usefull information!
