bermo Posted April 18, 2018 Share Posted April 18, 2018 As my car was in the shop getting an IWG set up done, I had the tech chase down an oil leak I suspected was coming from the turbo drain. Under idle (low oil pressure/low volume) is does not leak. Drive it normally and it leaves a puddle, drive it harder and you eventually can smell the smell. I am told it is leaking at the connection at the hard line (from head) to the rubber oil drain hose. Hose clamps have been tried. New drain hose has been tried. Turbo feed orifice checked for size. Hard line to head has been pulled and checked. There is no oil pressure in the drain, there should not be a level there, how is this leaking?? How does the oil get back to the block from the head? Is there an oil passage through the head gasket? Any ideas would help out. Link to comment Share on other sites More sharing options...
birdmayne Posted April 18, 2018 Share Posted April 18, 2018 Sent a couple texts your way. Hopefully they help out. John Hancock Link to comment Share on other sites More sharing options...
gkinslow Posted April 19, 2018 Share Posted April 19, 2018 Sent a couple texts your way. Hopefully they help out. Not going to share with he class? Link to comment Share on other sites More sharing options...
birdmayne Posted April 19, 2018 Share Posted April 19, 2018 Noodz. The usual John Hancock Link to comment Share on other sites More sharing options...
bermo Posted April 19, 2018 Author Share Posted April 19, 2018 I'm wondering if the port through the head gasket has an obstruction, which would fill the head up with oil, which would back fill into the drain. But golly, that just seems silly. I kindathinkmaybe I remember there were two different head gaskets out there with different porting cutouts? But, that turbo drain should hold a static load anyways. Anybody ever see the hard line to the head have a crack? Link to comment Share on other sites More sharing options...
birdmayne Posted April 20, 2018 Share Posted April 20, 2018 PCV valve didn't remedy anything? My offer to borrow mine still stands John Hancock Link to comment Share on other sites More sharing options...
bermo Posted April 20, 2018 Author Share Posted April 20, 2018 He's putting in a new PCV today, I'm thinking it won't help. Link to comment Share on other sites More sharing options...
