2_Liter_Turbo Posted April 8, 2018 Share Posted April 8, 2018 I've been searching for the past hour or so and can't find anything, so hoping someone has a quick answer. In the middle of installed a Tomei EL Header on my Spec B, and I need to adjust the width a little to get it to fit. You're supposed to loosen the adjuster bar bolts and be able to move it along the slip joint, but it won't budge. I tried tapping on it with a hammer and of course grabbing it with brute strength, lol, but it's not moving at all. Anyone have the same issue? Trying not to damage these (they are new), but I also need to get them to move! Link to comment Share on other sites More sharing options...
relative4 Posted April 8, 2018 Share Posted April 8, 2018 Heat Link to comment Share on other sites More sharing options...
awesterner Posted April 8, 2018 Share Posted April 8, 2018 I was lucky with mine, but I did have to grind a bit of the motor mount to get it to fit on the studs (drivers side I think?) Link to comment Share on other sites More sharing options...
2_Liter_Turbo Posted April 8, 2018 Author Share Posted April 8, 2018 Heat Heated it up enough to turn blue, and it still won't budge. One side does, but the other one doesn't. Now the header looks like ass because it has a ton of marks on it from hitting it trying to get it to slip, lol. Link to comment Share on other sites More sharing options...
2_Liter_Turbo Posted April 8, 2018 Author Share Posted April 8, 2018 I was lucky with mine, but I did have to grind a bit of the motor mount to get it to fit on the studs (drivers side I think?) I have Group N mounts, and don't see any issues with mine. Link to comment Share on other sites More sharing options...
