Tire question - 2016 Legacy Limited
Posted
Hi everyone,
Been enjoying my Legacy for a little over a year now... starting to think a bit about replacement tires.
First, I'm looking for recommendations for good winter tires. The ones it came with are ok-ish, but I'd like something with a bit more meaningful tread.
Next - I don't mind switching between winter and summer tires. However, I am wondering if anyone has replaced the stock tires with anything a bit higher profile, and, if so, how this might affect performance (if it's even possible).
Can the rims / tires be replaced to get higher profile? It may be that higher profile tires would work to get deeper tread for winter.
Thanks!
Posted
Using 225/55R-17 Bone Blizzak WS80
17X7.5 Sport Eedition P2 Wheels from Tire Rack.
Very happy.
Lighting Mods
Low Beams: D4S - OSRAM XENARC 66440 CBI HID BULBS
Highbeam/DRL: 9005 - OSRAM NIGHT BREAKER UNLIMITED 9005NBUHCB BULBS
Fog: H11 - OSRAM NIGHT BREAKER UNLIMITED 64211NBU-01B BULBS
Subaru 20mm RSB
Posted
My summer tires are the original tires the car was purchased with on the OEM 18" rim.
My winters are Blizzak WS80 on a smaller rim (17").
Because I went down to 17" for my winter tires I have a larger profile on them.
Not sure if this is what you're looking for.
Posted
Has any one put Michelin Premier A/S? Ordered some from my local tire dealer.
Although, the ride and handling are great, it wears very prematurely.
Posted
If you go to a higher profile tire, you will lose some agility and cornering ability. But, you'll gain stiffness that won't translate into noise-vibration-hardness into the cabin.
I "downsized" my 09 Legacy from P215/45R17's to P205/55R16's. The original rims got so damaged and pounded with potholes, I decided to go to steelies, which were 16's. I got a slightly better ride, but I think a lot of that was because my rims weren't "skipping" due to them not being perfectly round.
Just make sure you can clear the calipers if you downsize. It's a very common thing for winters.
You'll have a TPMS light on if you can't clone the OEM sensors because it won't have the ability to communicate with them.
If you're looking for all-seasons, which I ran on my Legacy and run presently on my Outback, even in winter (and never had a problem), I love my Continentals. They've been great.
09 Legacy, purchased in August of 2008:
OEM Yokohamas, didn't like them, replaced when low tread.
Bridgestone Potenza Grid P205/50R17's in 2012. They were better than OEM but not very durable, had lots of pothole issues/replacements.
Continental PureContact P205/55R16's in January 2016. Replaced because of sidewall problems on the Bridgestones. Changed to 16" steelies here.
11 Outback, purchased in April 2011:
OEM Continental ContiProContacts P225/60R17, replaced when worn. They were okay.
Continental TrueContact P225/60R17, January 2015. These have been pretty good so far. Good winter performance - never wished I had a winter tire (yet.)
I also considered the Michelin Premier A/S and Pirelli Cinturato P7 A/S's. I'd probably go Pirelli's next time around, they have slightly higher marks at the cost of slightly less tread life.
Posted
Pirelli Cinturato P7 A/S's are fantastic. On my 2015 2.5, I replaced my OEM set at 5k mi with these. I will get these again, once I'm ready to replace the OEM set on my 2018.
Posted
Change the tire size in your search to 225/55/18, instead of the OEM 225/50/18 and you will find many more options. The size change is so small it will not make a diferenc to fit, but many more tires are available in the substituted size
