05LegacyGTGa Posted March 21, 2018 Posted March 21, 2018 I think I'm just going to replace the MAF sensor on my car to see if it fixes the terrible LV numbers I'm getting using the BtSsm App. Should I just go with a Denso one or are any of the other brands any good (like Walker etc from RockAuto or something off eBay)?
relative4 Posted March 21, 2018 Posted March 21, 2018 If you're just going to fire the parts cannon, get a Denso; anything else will cause problems. If you want to diagnose your problem, start by posting the LV here. Also all mods and current tune.
05LegacyGTGa Posted March 21, 2018 Author Posted March 21, 2018 It's completely stock. I'll get the LV off and put them up!
05LegacyGTGa Posted March 22, 2018 Author Posted March 22, 2018 Here's a few: BtSsm_LV_20180318_1229 by kornfan891, on Flickr BtSsm_LV_20180309_1909 by kornfan891, on Flickr BtSsm_LV_20180302_2148 by kornfan891, on Flickr BtSsm_LV_20180302_1935 by kornfan891, on Flickr BtSsm_LV_20180221_1416 by kornfan891, on Flickr
Perscitus Posted March 22, 2018 Posted March 22, 2018 A bit all over the place. That Mar-2nd LV looks fairly bad. Assuming that was before the MAF swap. Mar-19th looks better, but can be further improved. AF Learn A isnt ideal but nothing much to worry about. And the -2.8 deg FLKC learned somewhere between 1.65-2.6K RPM and 0 to 0.85g/rev is also irrelevant, out of boost, potentially false knock. See if IAM stays at 1 and if you can get the Timing correction matrix to fill in more with some drives that put you above 1, 2g/rev and across 1-5K RPM. If the Fuel and Timing learned values keep fluctuating, something else is still not right.
relative4 Posted March 22, 2018 Posted March 22, 2018 Who told you those numbers are terrible? For a stock tune, they're gRRREAT! Two recommendations: 1. Smoke test. You may have a very small vacuum leak. You can buy a paint can smoke machine for $80 from eBay, make your own, or borrow one. 2. Buy a Cobb AccessPort and flash the Stage 1 tune. In addition to improving performance substantially, it will help extend engine life by reducing the likelihood of burnt exhaust valves. Edit: I was really just looking at the 2 most recent snapshots, under the assumption that you fixed whatever was causing all the earlier fluctuations. If that's not the case, and you're still fluctuating, I would start by checking the grounds, and then follow the recommendations of Perscitus, who is far more knowledgable than I.
05LegacyGTGa Posted March 22, 2018 Author Posted March 22, 2018 I haven't touched it other than for the 3/18 one it has new plugs in it. Thought I might start with the MAF. I'll do some logs tomorrow and post them up.
relative4 Posted March 22, 2018 Posted March 22, 2018 Then yeah, check the grounds, and include roughness counts in the logs. What plugs did you use?
05LegacyGTGa Posted March 22, 2018 Author Posted March 22, 2018 What's the best way to attach a log file (Excel)?
05LegacyGTGa Posted March 22, 2018 Author Posted March 22, 2018 Nevermind. I think I figured it out.BtSsm_20180322_134232_knock.csvBtSsm_20180322_135358.csv
05LegacyGTGa Posted March 23, 2018 Author Posted March 23, 2018 Anybody? I go cross-eyed looking at it ha
relative4 Posted March 23, 2018 Posted March 23, 2018 Personally, I've never looked at logs from an auto before, so I can't say much helpful. The boost targets seem low, and the wastegate duty cycle looks weird to me, but auto, so I dunno. However, I definitely stand by what I first said - smoke test. Looking at the log with the knock, looks like things go a little haywire when you shift. 1->2: You go crazy lean, RPMs drop all the way down under 1000 - is that normal? 2->3: Crazy lean again, RPMs only to 1600 this time, knocks occur presumably because of the lean mixture. I think the extra-high vacuum happening during the shifts may be sucking open a minor vacuum leak that doesn't have much effect under other conditions. I have no idea if the way it's shifting is normal.
05LegacyGTGa Posted March 24, 2018 Author Posted March 24, 2018 I've been told before that the auto will show a decent amount of false knocks.
