wbrawley Posted March 20, 2018 Posted March 20, 2018 On the Energy suspension website it only shows the non-greasable bushings (part 19.5105). But I want to find which ones have the bracket with the grease fittings.
relative4 Posted March 20, 2018 Posted March 20, 2018 What diameter sway bar are you using? Here's the full RSB kit I put together last year, with part numbers and cheapest sources at that time. I used the greasable bushings.Sway bar.csv
wbrawley Posted March 20, 2018 Author Posted March 20, 2018 Stock sway bar, can't remember if it's 20 or 22mm.
traildogck Posted March 20, 2018 Posted March 20, 2018 Stock front is a 21mm bar. There were a few out there with 20's I forget the specific model. It would be easy enough to install a zerk in the OEM strap and drill the bushing. Folks have already aksed me about producing greasable kits. It's not cost effective for me at all. But I can certainly produce a drilled bushing and you can drill, tap and install a fitting in your OEM strap. I have told others the same thing. Problem solved. CKE SSP product information and sales : chris.ckessp@gmail.com
wbrawley Posted March 20, 2018 Author Posted March 20, 2018 Stock front is a 21mm bar. There were a few out there with 20's I forget the specific model. It would be easy enough to install a zerk in the OEM strap and drill the bushing. Folks have already aksed me about producing greasable kits. It's not cost effective for me at all. But I can certainly produce a drilled bushing and you can drill, tap and install a fitting in your OEM strap. I have told others the same thing. Problem solved. That's my whole problem, went to replace bushings and the driver's side bracket is bent. So, I just wanna replace the whole assembly and Energy brand seems the best deal for $25 unlike OEM is $50-100 just for brackets.
traildogck Posted March 20, 2018 Posted March 20, 2018 I think I saw that comment in a thread. Did you ever contact SuperRupair and see if they would send you one? I have used the same Energy Suspension strap and pushing kit on my XJ/Cherokee and one of the old solid axle Suburbans. They are what you would expect for $25. The slotted strap needs to be torqued way down to stay in place up front. Those 8x1.25 weld nuts in the subframe can strip out easily...Believe me, I know. I am always messing with bushings. Energy Suspension poly nothing special either. It's hard, dry ... prone to squeaks. If I had a spare strap, I'd send you one. CKE SSP product information and sales : chris.ckessp@gmail.com
traildogck Posted March 20, 2018 Posted March 20, 2018 Yeah. I just talked to my buddy Doug. I can get them all day long. Cheap also. I might just go stockplie a bunch They do pull down a pretty penny at the dealer. You should have me make you a greaseable set in the OEM design. CKE SSP product information and sales : chris.ckessp@gmail.com
wbrawley Posted March 20, 2018 Author Posted March 20, 2018 Yeah. I just talked to my buddy Doug. I can get them all day long. Cheap also. I might just go stockplie a bunch They do pull down a pretty penny at the dealer. You should have me make you a greaseable set in the OEM design. So, you just take the stock ones and drill out and attach Zerk fittings? Do you need a hole through the bushing or does it grease around the outside of the bushing?
traildogck Posted March 20, 2018 Posted March 20, 2018 So, you just take the stock ones and drill out and attach Zerk fittings? Do you need a hole through the bushing or does it grease around the outside of the bushing? Yep, drill the strap. Tap it or just run in a zerk. Then yes, the bushing would need to be drilled (same location) to the center diameter to allow a duct for the grease. It's pretty simple. I drilled out some rear AVOs a few years back. I don't run that AVO bar anymore and I haven't had the need to develop any greasable in my stock design. I just run a stock strap, bar, and 85d rear sway bushing on both my cars. CKE SSP product information and sales : chris.ckessp@gmail.com
wbrawley Posted March 20, 2018 Author Posted March 20, 2018 Yeah, and it's the front sway bar bushings by the way. Dunno if that changes Energy part # or not?
