Winesalot Posted March 20, 2018 Posted March 20, 2018 I had a 95 that gave up on me. I bought a 97 to replace it which had a bad window switch in the drivers door. Luckily I had not sent the 95 off to the dead car afterlife so I pulled the switch and the 97 had full window operation. Now, a couple years later my daughters 95 drivers window switch has failed. I am bit Leary of a wrecking yard replacement as it appears to be a common problem. Wondering if anyone knows a good (read that as inexpensive) source for a new replacement?
