swingminx Posted March 5, 2018 Posted March 5, 2018 Hi. I am looking for trunk lift supports replacement for my GTB wagon. My local Subaru dealer was EXPENSIVE(101 pound! Anyone how can help me find any good aftermarket or OEM and knows the parts number that is not so expensive? Regards Per from Sweden
swingminx Posted March 6, 2018 Author Posted March 6, 2018 https://m.ebay.com/itm/Trunk-Tailgate-Lift-Support-Shock-Strut-Damper-Subaru-Legacy-Outback-2pcs-/271913455177 Anyone know if these will fit? They have gotten some bad reviews. If anyone can help me with the OEM partsnumber i will be very thankful.
YeuEmMaiMai Posted March 6, 2018 Posted March 6, 2018 take OEM part number and type it into your favorite search engine, pick result you want.
swingminx Posted March 7, 2018 Author Posted March 7, 2018 take OEM part number and type it into your favorite search engine, pick result you want. Thats the problem, i dont know the OEM part number.
YeuEmMaiMai Posted March 7, 2018 Posted March 7, 2018 it should be stamped on the strut these will fit 2000-04 wagons Subaru OEM part numbers left 63269AE030 right 63269AE020
swingminx Posted March 8, 2018 Author Posted March 8, 2018 The only number that was stamped on one of mine was : 2IG29 I cant find any of those when i search on google. I wonder if mine is the same as the 00-04 models?
RustyRuu Posted March 8, 2018 Posted March 8, 2018 You could bend them, either take them off or try on the car. Have them fully extended and put a big enough bend in it so it can't just slide down and got your head. You will have to force it up and down a bit now but it won't fall on you until your new ones arrive or you can deal with it as is an never buy those lifter/ hydraulic things again
YeuEmMaiMai Posted March 9, 2018 Posted March 9, 2018 The only number that was stamped on one of mine was : 2IG29 I cant find any of those when i search on google. I wonder if mine is the same as the 00-04 models? both of the numbers i provided will return oem and compatible aftermarket parts
swingminx Posted March 10, 2018 Author Posted March 10, 2018 both of the numbers i provided will return oem and compatible aftermarket parts But mine is a 1999 model and you wrote 00-04 so i was not sure if the would fit.
RumbleRumble Posted March 13, 2018 Posted March 13, 2018 But mine is a 1999 model and you wrote 00-04 so i was not sure if the would fit. USA legacys 2000-2004 JAP,AUZ,EUR 1999-2003
