l88m22vette Posted March 3, 2018 Share Posted March 3, 2018 (edited) So, I've been screwing around with my laptop for the better part of a week - clean Win7 install, downloaded RomRaider, ECU Flash, and everything that I believe is needed to support those (ECU definitions, etc). I've read through 5+ how-tos and still can't get Logger to just run correctly. Are the 8+year-old stickys from the RomRaider forums the best versions of the programs and definition/.xml files? I always get an error stating it doesn't have car definitions but I've tried adding that into the logger definition location, when I do that I then get a no ECU definition error. Everything is in one folder under c:/programs, and I don't get an error with RR's ECU Editor. I've also been trying to get Logger to recognize my Innovate LC-2 through the Tactrix, I bought the 2.5mm jack adapter so I could log wbo2 together with everything else. Even though its selected AND I've set the plugin as COM3 (same as the Tactrix) I get nothing. I wish someone would just put everything needed into one neat, updateable package, its a great program but can be a real pain. Edited March 3, 2018 by l88m22vette Link to comment Share on other sites More sharing options...
awesterner Posted March 5, 2018 Share Posted March 5, 2018 When I was using RR I would always get a warning on opening that 'car definition not found'. It would ask me to go online to download..I would click "no". Let the logger contuinue to open, then minimize Editor. Logger would work. I had to edit through ECU Flash, and RR dyno never worked. Using the LC2 was a major frustration. Some days it would work, some days I would have to fight it. Innovate has two options under the Switches tab, and I had my best luck with the 'Innovate wideband AFR'. One thing I did realize is that you cannot run the Innovate logger and RR at the same time...well you could but nothing useful will register on RR Link to comment Share on other sites More sharing options...
bigleben Posted March 5, 2018 Share Posted March 5, 2018 I can't say if LC-2 is any different but logging with my LC-1 on RR I had to use a serial to USB cable on a different COM to my tactrix. 1- I've setup the correct AFR data (gasoline) on logworks (innovate WB setup program), you do it once unless things are messed up. 2- Once the laptop is open, plug both USB cable : tactrix and LC-2. 3- Open RR logger and should see data from the tactrix (if car runnning) 4- Select correct COM in pluggins for your WB (different from tactrix) 5- Go to ''external pluggins'' IIRC and select the correct WB sensor. That's how I make my LC-1 works with RR logger. GL Link to comment Share on other sites More sharing options...
l88m22vette Posted March 6, 2018 Author Share Posted March 6, 2018 Ok cool, thanks for the feedback, I have been just clicking past the RR error message and it does log (everything but the Innovate, anyway). I'll re-do the full sensor calibration, just in case, and I got a serial-to-USB adapter so I'll try that route instead and will set a different COM# Does anyone know if the 2.5mm jack adapter actually works through the Tactrix? This is the best info I've found, I guess I'll have to throw in some code to make it work: https://www.evolutionm.net/forums/09-ralliart-engine-turbo-drivetrain/541627-tactrix-openport-standalone-logging-0-5v-adc-op2-0-pin-8-a.html Link to comment Share on other sites More sharing options...
l88m22vette Posted March 13, 2018 Author Share Posted March 13, 2018 Ok, got it to work, I skipped dicking around with the 2.5mm jack and just bought a serial-to-USB adapter and went through the whole Innovate setup again (setting the sensor to AFR), it works perfectly and logged in RomRaider Link to comment Share on other sites More sharing options...
