Wasted Potential Posted January 9, 2018 Share Posted January 9, 2018 Moved to proper sectionTA - WOT Log for Revision 1 recorded 01092018.csv Link to comment Share on other sites More sharing options...
Wasted Potential Posted January 9, 2018 Author Share Posted January 9, 2018 EDIT: WRONG SECTION - I apologize Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 12, 2018 Share Posted January 12, 2018 I got you squared away to the proper section. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
covertrussian Posted January 17, 2018 Share Posted January 17, 2018 Just over 5% is normal. Different air density day to day will mess with this correction. When you get to 10% start thinking about it, when it gets to 15% it will hit the ceiling and throw a CEL. At this point you probably have a leaky injector or something else causing over fueling. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
