91 subaru Legacy heater blower
The fuses check out. The blower fan is good (I pulled it out first and tested it). I pulled out the control panel in the dash board and there is no power getting to the fan speed selector switch. Is there anything between the fuses and the fan selector switch? There is a thing at the top of the fuse box labeled "main fan". Is this a relay for the blower fan?
  • 2 weeks later...
Hello;
When I purchased my first gen station wagon the heater motor did not work. Pulled the heater motor and cleaned out the mouse nest and checked the motor (good). On the housing next to the heater motor is the heater resistor and fuse module. Mine was faulty and this fixed my non-functioning heater. The main fan fuse you saw is the cooling fan. I would suggest that you explore the sticky at the beginning of the first gen page. Search that website and see if the shop manual is still there, Steven.
