Rear Hub Assembly
Ok so I did my homework and search for this I have 2 options
TIMKEN HA590119 or NSK WO133-1805930 which are both available in store.
My question is are those bearing similar to each other? I’m doing this project since I’m off from work due to holidays
http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html
The correct Moog number is in that thread.
Read the sticky's...
Engine Build - Click Here
Moog is more expensive than the Timkens!
Thanks for the update, I haven't checked prices in years.
But FWIW. I do have a spare new front Timken in the shed.
Hi MAX I’m putting my rear hubs today I’ll see how it goes once I’m done if the car will be quieter. Rears are known to fail I’m not sure on the front. But would you mind if I ask how much it will cost for your front hubs please PM me, I hope the shipping won’t kill me, thanks.
Loose screw, inside the rear diff, ? So you removed the rear diff and pulled the cover off it ?
Yes! I drained the oil, but I see some debris in it which have mix of silver and oil, so I pry off the cover which I see the screw inside.
Recently I have a binding issue with my differential which is causing by the Transfer Clutch Clutch and fix it already, probably this is the effect of the binding issue.
I’m replacing my rear differential soon.
