Great White Buffalo Posted December 21, 2017 Share Posted December 21, 2017 I have a '94 Subaru Legacy L , i just bought it about 3 months ago . It has just over 92,000 miles on it and i just discovered an oil leak and don't know where it could be coming from. Also when i make left turns my axle make clicking noises. I've been searching for parts but idk if i should get just the front left or the full assembly. Any advice would be appreciated:confused::confused: Link to comment Share on other sites More sharing options...
RumbleRumble Posted December 23, 2017 Share Posted December 23, 2017 you have a second gen legacy. Is it FWD or AWD? Spray some brakeclean under the engine where it's wet and cruddy then start the car and look. Oil can travel down and around things when you drive. You can just get the front left you dont need both if the only one is good. Link to comment Share on other sites More sharing options...
ehsnils Posted December 24, 2017 Share Posted December 24, 2017 Make sure that it's the left side the noise comes from and check the wheel bearings as well. Sometimes it's the inner joint on the right side that goes first because it's heated by the exhaust. Took me a while once to figure that one out. Link to comment Share on other sites More sharing options...
