Door compatibility?
Hi All,
Recently, my 08 legacy 3.0R limited was hit by someone while parking on the street. Damage was pretty nasty with large area dents, two deep grooves, bent molding and paint chipping. Feeling little hope finding out who did it while the insurace deductible is very high (1k), I decided to try repair my self.
The result was not good either, so I went to see if there is door with matching color available. It turns out there is one 3 hours away (gold color seems to be rare:rolleyes:) from a 08 base trim legacy @$200. So here is the question, anyone know if it is compatible with 3.0 limited model? I think it should but a confirmation will be great:spin:. Any other suggestion is also appreciated.
Cheers,
Han
Based on opposedforces.com it looks like as long as you're not getting the door from an Outback or any other earlier-model Legacy (MY05-07) then the door is identical for your 3.0R. You should be good.
'08 3.0R Door Page: http://opposedforces.com/parts/legacy/us_b13/type_13/body_equipment_exterior/front_door_panel_and_rear_slide_door_panel/illustration_1/
'08 2.5 Base Door Page: http://opposedforces.com/parts/legacy/us_b13/type_14/body_equipment_exterior/front_door_panel_and_rear_slide_door_panel/illustration_1/
