Trans swap
Even with single cam and dual cam
Sent from my SM-G930V using Tapatalk
Yes. The bolt pattern is still the same, the block does not determine weather or not the engine is SOHC or DOHC, but rather the heads.
you will have issues with speed sensor compatibility. its something like 95-98 is different and 05+ are different as well i'm not sure how easy it is to change them about but a gps could tell you speed...
speedometers are not too important just drive so fast that the cops cant catch you at all times:rolleyes:
So if I wanted to I could put a 03-04 wrx trans in my car 03 legacy gt that has a ej25 single cam na ?
Technically it will bolt up but some modifications would be needed, those trans, I believe, have a different style clutch release fork. I don't know if the throw out bearings are compatable betwebetween the two haven't made it that far into my research am about to tackle this myself. I think there are holes tapped into the case so you are able to just mount the pivot bolt in the right place to use the legacy style fork.
The slave cylinders are also different too, one pushes and on pulls, I think once you figure the fork out you can mount the legacy stuff up no problem
