H2OSB Posted December 14, 2017 Share Posted December 14, 2017 I looked through both the fourth gen section as well as this one and didn't see anyone else asks about my issue. My car is a 2006 LGT with 65 miles shy of 80K. Earlier this year, my turbo failed. I replaced it myself with a non-factory stock replacement turbo. All went well, for the most part, and the car has been running fine. The only issue I've seen is the temperature on the gauge has been showing almost exactly at the mid point, where is used to run right at around the first mark. I chalked this up to the fact I lost a little of the original coolant when I drained the radiator for the turbo replacement (I kept the original coolant in a closed container so I could reuse it when I got the turbo replaced). Tonight, I finally got some coolant (Peak Global) to top it off. I added coolant to the fill point on the overflow bottle then ran the car to warm up temp. The temp, again, went up to the midpoint on the gauge. I took the car for a drive, and the needle went up to just below the line below the red zone. What could cause this? I've had no CELs, and the car has been running well. I'm concerned the car will overheat when I drive to work tomorrow (about a 10 mile drive). Thanks in advance H2OSB Link to comment Share on other sites More sharing options...
Infosecdad Posted December 14, 2017 Share Posted December 14, 2017 Air bubble will do that, have you tried burping it? Link to comment Share on other sites More sharing options...
H2OSB Posted December 14, 2017 Author Share Posted December 14, 2017 no, can you tell me how? For some reason, I feel a bubble is likely Link to comment Share on other sites More sharing options...
spacemanspif Posted December 14, 2017 Share Posted December 14, 2017 Mrs Spif's 05 LGT always rides at the half mark on the gauge. Subaru did a coolant flush when we did the timing belt and nothing changed. What temp is the thermostat rated at and where is the gauge supposed to read under normal operation? Link to comment Share on other sites More sharing options...
Infosecdad Posted December 14, 2017 Share Posted December 14, 2017 Here is the procedure out of the service manual, start at Step 9. Link to comment Share on other sites More sharing options...
H2OSB Posted December 14, 2017 Author Share Posted December 14, 2017 thank you! Link to comment Share on other sites More sharing options...
H2OSB Posted December 14, 2017 Author Share Posted December 14, 2017 That did the trick! Thank you very much! H2OSB Link to comment Share on other sites More sharing options...
