bobinnv Posted December 13, 2017 Share Posted December 13, 2017 I've been playing music from my iPhone 7+, via "Music" thru my 2015 Legacy sound system for over a year. It still works in general, but it seems more and more I get a variety of errors: - plays correctly, but the dash display doesn't show title, artist, etc - playback freezes, but the dash display looks correct - plays but starts skipping - waits for several minutes before playing music after the car starts These problems usually clear up if I restart the phone (or the car). I'm up to date on Apple software, don't know if there has been a firmware release for the Legacy. And I can't say any particular release started these problems, things just seem to have gotten worse with time. I'm just trying to find out if anyone else experiences these issues, or if there might be a fix. TIA Link to comment Share on other sites More sharing options...
Pilot1226 Posted December 14, 2017 Share Posted December 14, 2017 You're connecting with Bluetooth, I assume? Have you tried connecting via the Aux connection, just to see if you have the same issues with Aux? Link to comment Share on other sites More sharing options...
bobinnv Posted December 14, 2017 Author Share Posted December 14, 2017 You're connecting with Bluetooth, I assume? Have you tried connecting via the Aux connection, just to see if you have the same issues with Aux? Yes, Bluetooth. I've never even tried the Aux connection.. Link to comment Share on other sites More sharing options...
DA_MAXX Posted December 15, 2017 Share Posted December 15, 2017 bobinnv, I have a 15,prem, w/nav. My headunit is running NU9017 update. Use iphone 6 plus, w?ios 11.2.1. I connect via bluetooth 95% of the time. I use TuneIn or Pandora. I've never had issues with skipping. The audio sounds fine. It does drop every now and then when I temporarily loose connection. The display does lag, when it comes to songs\artist info. I find that Pandora works the best, full control, when connected to usb port vs. bluetooth. Link to comment Share on other sites More sharing options...
bobinnv Posted December 15, 2017 Author Share Posted December 15, 2017 bobinnv, I have a 15,prem, w/nav. My headunit is running NU9017 update. Use iphone 6 plus, w?ios 11.2.1. I connect via bluetooth 95% of the time. I use TuneIn or Pandora. I've never had issues with skipping. The audio sounds fine. It does drop every now and then when I temporarily loose connection. The display does lag, when it comes to songs\artist info. I find that Pandora works the best, full control, when connected to usb port vs. bluetooth. Thanks.. I'll try Pandora for a while to see if I have problems - maybe its the Apple Music app Link to comment Share on other sites More sharing options...
