2016昴 Posted December 10, 2017 Share Posted December 10, 2017 Hi nice to meet you all. I have a question on LED headlight. I recently purchased a set of LED light bulbs and installed them on 2016 Legacy. However, now the high beam comes on when the orange running lights are supposed to be on. In order for me to shut the high beam during day, I have to turn on the head light (low beam, of course). Can we fix this or I have to get another set of LED? Link to comment Share on other sites More sharing options...
upstater Posted December 10, 2017 Share Posted December 10, 2017 the DRL resistor sends a lower current to the halogen high beam bulb that makes it glow. But that same low current sent to an LED bulb will fully light it. So you need to put the halogen bulb back in, or drive around with your LED in the high beam position, most likely at full brightness. Or turn on the low beams, which disables the DRL signal, as you discovered. Link to comment Share on other sites More sharing options...
securityguy Posted December 10, 2017 Share Posted December 10, 2017 I left my LED bulbs in and drove around all day every day with the DRLs in high brightness. Did this for over 2 years with out ever an issue. No one ever flashed their lights at me and I felt even safer as I knew I would aways be seen. Personal preference and your call but normal and I would just leave them alone and let them stay full bright. Link to comment Share on other sites More sharing options...
tornichoe Posted December 11, 2017 Share Posted December 11, 2017 I left my LED bulbs in and drove around all day every day with the DRLs in high brightness. Did this for over 2 years with out ever an issue. No one ever flashed their lights at me and I felt even safer as I knew I would aways be seen. Personal preference and your call but normal and I would just leave them alone and let them stay full bright. Its just people giving up on these folks. Its not like you are going to go put your halogens back coz someone flashed at you. They are also extremely annoying to the car in front of you, especially at dawn and dusk. Its for this very reason that I have my light sensor covered so the auto dimming mirrors are all dark anytime they pick up light coming from behind. Link to comment Share on other sites More sharing options...
tornichoe Posted December 11, 2017 Share Posted December 11, 2017 Hi nice to meet you all. I have a question on LED headlight. I recently purchased a set of LED light bulbs and installed them on 2016 Legacy. However, now the high beam comes on when the orange running lights are supposed to be on. In order for me to shut the high beam during day, I have to turn on the head light (low beam, of course). Can we fix this or I have to get another set of LED? Search for the DRL disable or switchbacks in the search feature on the top right. If you want to keep your LED high beams, its best to do one of those two mods. Link to comment Share on other sites More sharing options...
ehsnils Posted December 11, 2017 Share Posted December 11, 2017 DRLs in main beams is a nuisance. Better to run the low beams or to have separate DRL lamps. Euro vehicles have a combined fog/drl lamp. Link to comment Share on other sites More sharing options...
2016昴 Posted December 13, 2017 Author Share Posted December 13, 2017 So I unplugged the DRL disable plug and it works!!! Thank you. Link to comment Share on other sites More sharing options...
