Sololeggy Posted December 9, 2017 Share Posted December 9, 2017 Hey I replaced my right rear axle pulled it out and put a new one in but it's not going fully into the differential, can anyone help me or tell me what I can do to fix it??? Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted December 9, 2017 Share Posted December 9, 2017 Did you line up the splines the right way? Try flipping it 180 Link to comment Share on other sites More sharing options...
Sololeggy Posted December 16, 2017 Author Share Posted December 16, 2017 Did you line up the splines the right way? Try flipping it 180I did I tried everything but it stickes out about an inch inch and a half from the diff like something is stopping it and idk what. Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
Sololeggy Posted December 16, 2017 Author Share Posted December 16, 2017 I did I tried everything but it stickes out about an inch inch and a half from the diff like something is stopping it and idk what. Sent from my SM-G930V using TapatalkOne is original (brand new axle i just been playing wit it in the diff so its dirty) u can see everything and the other is where it stops in the diff Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted December 17, 2017 Share Posted December 17, 2017 compare the axles next to each other. make sure the joints are together when you push it in. where or what car is that axle is from? Link to comment Share on other sites More sharing options...
Setnev Posted December 17, 2017 Share Posted December 17, 2017 You need to slam it in there. Smack it in there like it owes you money. You see that groove on the tip of the shaft? There a clip inside the diff that holds it in there. Its a pressure clip and requires a bit of force to get it to expand and slip over the head of the shaft. That's also why the shaft is tapered. This also sounded way dirtier the second time I read it. Link to comment Share on other sites More sharing options...
Sololeggy Posted December 17, 2017 Author Share Posted December 17, 2017 compare the axles next to each other. make sure the joints are together when you push it in. where or what car is that axle is from?2003 subaru legacy gt limited Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
Sololeggy Posted December 28, 2017 Author Share Posted December 28, 2017 You need to slam it in there. Smack it in there like it owes you money. You see that groove on the tip of the shaft? There a clip inside the diff that holds it in there. Its a pressure clip and requires a bit of force to get it to expand and slip over the head of the shaft. That's also why the shaft is tapered. This also sounded way dirtier the second time I read it.I've tried to do that still won't go in still popped out Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted December 30, 2017 Share Posted December 30, 2017 what kind of car do you have? do you have a gt? they have different rear diffs from Ls Link to comment Share on other sites More sharing options...
