Tpms
... [in] a 16 Legacy Is there any way to see the tire pressure in each tire ...
No. You have to use an old-fashioned (Gasp!) tire gauge.
"If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland)
You can also use a TPMS tool like the Autel MaxiTPMS TS501. I have used it on my '17 OB; you can use it to interrogate the TPMS via the OBDII port to read the current tire pressures. If you've read in the sensors using their initialization procedure, it will even display the pressure of each tire labeled with the correct corner of the car.
I use mine primarily to program the TPMS with the correct sensor IDs when I rotate tires - I use a 5-tire rotation (full-sized spare) and set the current 4 in the TPMS computer.
http://legacygt.com/forums/moz-extension://176116eb-f2e3-4542-9853-d50e14b56469/img/informenter-marker-1.pnghttp://legacygt.com/forums/moz-extension://176116eb-f2e3-4542-9853-d50e14b56469/img/informenter-marker-1.png
