Ddhiggins Posted December 2, 2017 Share Posted December 2, 2017 My 1995 subaru legacy makes a squeak-squeak-squeak sound when it is in reverse gear; and moving backwards....If; while I am moving backwards; and I shift to neutral; the noise stops; while I continue to roll backwards....this squeak occurs without application of the brakes; and continues with the application of the brakes; and continues as I gently ride the brakes as it rolls backward..it squeaks only when the vehicle is in reverse gear; and moving backwards..... any ideas as to what this is???? Link to comment Share on other sites More sharing options...
doublechaz Posted December 3, 2017 Share Posted December 3, 2017 Carrier bearing? I don't know. That's a weird one. Four jack stands or a lift and get under it while it is 'driving in reverse' until you can point to the sourse. Link to comment Share on other sites More sharing options...
