2Quiker Posted November 29, 2017 Share Posted November 29, 2017 So i took my 2015 legacy for a wheel alignment and the shop indicates that they cant do a alignment becuase the factory control arm cant be adjusted and they need to replace it with an after market one to be able to adjust the camber. My tires were worn on the inside. So i am wondering if this is true, do need an agter market control arm to adjust the camber?. Link to comment Share on other sites More sharing options...
ammcinnis Posted November 29, 2017 Share Posted November 29, 2017 Is the rear camber out of spec? If not, why mess with it? If it is, something may be bent and in need of replacement. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
2Quiker Posted November 29, 2017 Author Share Posted November 29, 2017 Is the rear camber out of spec? If not, why mess with it? If it is, something may be bent and in need of replacement. Yes it is off. See attached, i should have attached it on my first post, sorry. Link to comment Share on other sites More sharing options...
Da Roo Posted November 29, 2017 Share Posted November 29, 2017 Do you have warranty still? I'd go to the dealer for this one. Sent from my LG-H871 using Tapatalk Link to comment Share on other sites More sharing options...
2Quiker Posted November 29, 2017 Author Share Posted November 29, 2017 I have the extended warranty. Please excuse me buy what i would i have the dealer warranty, the bad control arm? Link to comment Share on other sites More sharing options...
Opie Posted December 1, 2017 Share Posted December 1, 2017 Something is bent, have them find that and fix it. An adjustable control arm will just hide the problem...not fix it. Link to comment Share on other sites More sharing options...
2Quiker Posted December 2, 2017 Author Share Posted December 2, 2017 Something is bent, have them find that and fix it. An adjustable control arm will just hide the problem...not fix it. What are some of the things that can be bent? I would like to know so i can ask them to check those things. Link to comment Share on other sites More sharing options...
