zactek Posted November 28, 2017 Share Posted November 28, 2017 Hey all, got 2 unrelated questions: 1. My tranny dipstick is reading a tick below low when cold. How much tranny fluid do I need to get it to read full? 2. It's an 05 GT with 110k miles on it,should I be using a heavier oil or stick with the 5w30?.(I only use Amsoil so the brand is not in question) TIA,Zack K. Link to comment Share on other sites More sharing options...
MTBwrench Posted November 28, 2017 Share Posted November 28, 2017 1) Reading the oil level when the trans is cold is a shot in the dark. The "standard" procedure(outlined in the manual) is to check fluid when it's level surface, warmed up, engine on, and trans in park. Don;t get it to read full, as an overfilled trans is worse off than an underfilled one. I usually shoot for 1-3mm below the full-hot mark. Also, use ONLY Subaru or Idemtisu ATF-HP. I know some have used Amsoil as well, but these trans's are fairly picky from what I've heard. 2) Amsoil 5w30 is more than plenty. If you plan on playing racecar a lot(autocross, tack time) maybe consider 5w40. MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
zactek Posted November 28, 2017 Author Share Posted November 28, 2017 1) Reading the oil level when the trans is cold is a shot in the dark. The "standard" procedure(outlined in the manual) is to check fluid when it's level surface, warmed up, engine on, and trans in park. Don;t get it to read full, as an overfilled trans is worse off than an underfilled one. I usually shoot for 1-3mm below the full-hot mark. Also, use ONLY Subaru or Idemtisu ATF-HP. I know some have used Amsoil as well, but these trans's are fairly picky from what I've heard. 2) Amsoil 5w30 is more than plenty. If you plan on playing racecar a lot(autocross, tack time) maybe consider 5w40. My tranny dipstick has a cold full and low mark,and a hot full and low mark. Since I had this option,J figured I can top it off without burning myself. I usually check tranny fluid when hot . I only use Amsoil for engine oil, not the tranny. Subaru or Idemitsu are the only ones I put in the tranny. Zack K. Link to comment Share on other sites More sharing options...
