bdcvg Posted November 24, 2017 Share Posted November 24, 2017 Just installed a steel wheel snow tire package and now there is a grinding noise during sharp turns. I assume it's brake disc grinding on something, is there really that much deflection in the brake rotor or is My wheel bearing a little sloppy? I posted this in the Outback section too. I have an '08 OBXT and it is stock. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted November 29, 2017 Share Posted November 29, 2017 I've seen some really crappy steel rims that deform very easily. Link to comment Share on other sites More sharing options...
jrho Posted November 30, 2017 Share Posted November 30, 2017 It could be something as simple as the brake shield being slightly bent during install and now rubbing on the rotors. Link to comment Share on other sites More sharing options...
JF1GG29 Posted November 30, 2017 Share Posted November 30, 2017 It could be something as simple as the brake shield being slightly bent during install and now rubbing on the rotors. This is probably the most likely. Link to comment Share on other sites More sharing options...
willg Posted December 6, 2017 Share Posted December 6, 2017 Just installed a steel wheel snow tire package and now there is a grinding noise during sharp turns. I assume it's brake disc grinding on something, is there really that much deflection in the brake rotor or is My wheel bearing a little sloppy? I posted this in the Outback section too. I have an '08 OBXT and it is stock. Could be the tire slightly rubbing the fender liners at full lock or under the compression of the suspension. Link to comment Share on other sites More sharing options...
