Power windows/sunroof/ABS NW
While puttering around town the power windows and sunroof stopped opening & the ABS light on the instrument panel is lit- I tried the switch that disables the windows by the window switches to no avail. I'm guessing this stuff is all on the same fuse; at least it crapped out with all the windows closed! Any ideas?:mad:
Uh... check your fuses
You definitely have a blown fuse. The fuse that controls the windows is fuse 18 in the fusebox. Looking at the schematic, that fuse leads to 3 circuits:
FB1 which gives power to:
ABS control module
Main fan relay (4-cylinder engine model)
Main fan relay-1 (6-cylinder engine model)
Main fan relay-2 (6-cylinder engine model)
VDC control module
FB20, which provides power to:
AT shift lock control module
Back-up light switch (MT)
Cruise control module
Inhibitor switch (AT)
Power window relay
Wiper deicer relay
Wiper deicer timer
and FB-21 which provides power to the Cruise Control module.
ABS light came on because FB-1 cut power to the ABS module and the power windows and moonroof stopped because FB-20 cut power to the power window relay that feeds both the windows and moonroof.
Check that fuse ASAP because FB-1 also controls your fan relays too. Don't need your car overheating.
Refer to this chart for location of fuse 18 on the fuse block: attachment.php?attachmentid=9259&d=1345939231
Fuses blow either cause the circuit was overloaded or there was a short somewhere. Either from damage, loose connection or a slipped wire.
The number on the fuse indicates how many amps go through that system. That's why a lot of fuses piggy back off others. Ones that don't produce much amps. If you have too low or the wrong amp for the circuit it will also blow.
My cigarette light fuse would pop every time I put a new one in instantly. The ground connection on the 12v outlet was loose from when I took my bezel off.
You probably had a intermittent power surge.
You've got a short circuit in that system.
Since that circuit provides power to 3 different systems, isolate which system is causing the fault.
First, start with the easy things. In the information I posted a couple days ago, it says there are a couple relays that control the fans. Check the cooling fan wiring for frays or breaks. Next the ABS module. There is a relay in the ABS module that frequently causes issues. Trace the wiring to the relay and see if the ABS is staying on after you turn off the key. You'll hear a buzzing inside the ABS control module if it is.
  • 1 year later...
I know this has been a while back, but i have this issue now, ive checked all fuses most relays and there fine, none of the windows roll down, now does my sunroof work, and my abs light is on i dont hear no relay clicking like other people do long tory short i pulled my dash harness to get it merged and putting it back in i wanted to make sure everything was fine before i put my dash back in and baaamn windows dont work i doubt ive left something unplugged i dont see anything unplugged back to the problem fuses check out idk where the window relay might be or the circuit breaker, might even be my window switch stopped working.. but i need help ASAP before i assemble my dash back in i want to make sure i get this fixxed...
