Enlight Posted November 18, 2017 Share Posted November 18, 2017 I need help diagnosing a knocking sound my car makes upon engaging first gear. I've read the various threads on shudder/stutter but this does not sound like it. Relevant details is that the second owner (I'm fourth) performed a 6MT swap on it, and it has a Clutchmasters FX300 clutch. This problem did not exist when I first received the car. As you can see in the video, there's a significant amount of shaking that's transmitted through to the shifter. This can be felt throughout the car as well. This happens primarily when I'm in the process of engaging the clutch, before it has fully engaged. Once fully engaged it does not happen. However, I have been able to recreate this sound when accelerating hard at first and promptly getting off the gas. The car will lurch as a result of the engine braking, and this will replicate the sound. Is this a clutch issue? Transmission mount? Engine Mount? I live in NYC and slip the clutch often as a result. I also learned how to drive manual on this thing, so there was a lot of slippage in the first month that I owned her. Thanks for the help. [ame=http://www.youtube.com/watch?v=GATgsh521Jo]05 Legacy GT Noise - YouTube[/ame] Bessie II Link to comment Share on other sites More sharing options...
relative4 Posted November 18, 2017 Share Posted November 18, 2017 I would start by checking out the pitch stopper, tranny mounts, & engine mounts. Link to comment Share on other sites More sharing options...
JazzAvi8r Posted November 18, 2017 Share Posted November 18, 2017 i'm honestly not trying to be a dick here, but looking at your RPMs, it seems to me like it's a driver error. before I watched the video, I was thinking throwout bearing and maybe a worn transmission sleeve. but after watching the video, the only way i would be able to give a better solution is to drive it myself. Link to comment Share on other sites More sharing options...
DaveWaters Posted November 18, 2017 Share Posted November 18, 2017 Check the clearance between the fuel lines bracket and the fuse box. When the motor shakes the bracket can contact the fuse box and make quite a knock. And check your trans mount as relative4 stated..could be torn allowing a lot of play when you slip the clutch. Link to comment Share on other sites More sharing options...
Enlight Posted November 19, 2017 Author Share Posted November 19, 2017 Thanks guys, I will check the tranny, engine mounts and the fuel line bracket/fuse box. I know it's not the pitch stopper as I just checked it recently. JazzAvi8r, no offense taken. What kind of driver error combined with the revs do you think would replicate this sound? In the video there are examples of the sound being reproduced with high as well as low revs. Bessie II Link to comment Share on other sites More sharing options...
Enlight Posted November 20, 2017 Author Share Posted November 20, 2017 Got under the car today but couldn't determine anything conclusive. The transmission mount looks fine (it was also recently replaced by AZP a year ago), and the motor mounts look okay too, but I believe I will need to remove them completely to really examine them. I used a pry bar between the subframe and engine to see how much movement there was, but I don't really have a point of reference to know what is the acceptable range. The driver side did seem to move more easily than the passenger. Bessie II Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 20, 2017 Share Posted November 20, 2017 Drive shaft center support bearing Link to comment Share on other sites More sharing options...
JazzAvi8r Posted November 20, 2017 Share Posted November 20, 2017 ^^ drive shaft center support bearing sounds pretty good. Enlight, after watching the video again, I do see the rattle at both high and low RPM. I apologize. does the car bog down at all after you get off the gas pedal? Link to comment Share on other sites More sharing options...
Enlight Posted November 21, 2017 Author Share Posted November 21, 2017 No apologies necessary. I can replicate the banging sound briefly by getting off the gas abruptly. Is this the center drive shaft support assembly I should be inspecting? I found it in TeriyakiBBS's thread. It doesn't look like Subaru sells that component - I have to get the whole propeller shaft assembly. What I'll do is inspect it to see whether it's just the bushings that need to be replaced. If so there is an aftermarket one offered by Driveshaft Shop. It looks like these things are also called carrier bearings. Bessie II Link to comment Share on other sites More sharing options...
Enlight Posted November 21, 2017 Author Share Posted November 21, 2017 Took a quick gander and it looks like the center bearing is fine. Bessie II Link to comment Share on other sites More sharing options...
Enlight Posted November 29, 2017 Author Share Posted November 29, 2017 Any other suggestions, besides engine and transmission mounts, before I crack open the transmission? CV axles were recently replaced. Bessie II Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 29, 2017 Share Posted November 29, 2017 Sounds internal but it might be a good idea to take it to a reputable shop in your area and have them put it on a lift. They should be able to quickly pinpoint the location. Link to comment Share on other sites More sharing options...
apexi Posted November 29, 2017 Share Posted November 29, 2017 I'd don't have much experience in this area, but I'd be curious to see if there is any play in center bearing. Link to comment Share on other sites More sharing options...
Enlight Posted November 29, 2017 Author Share Posted November 29, 2017 Sounds internal but it might be a good idea to take it to a reputable shop in your area and have them put it on a lift. They should be able to quickly pinpoint the location. Yeah, I just sent AZP an e-mail to see if they can diagnose it through the video. If not, I'll drove over and have them do it in person. I'd don't have much experience in this area, but I'd be curious to see if there is any play in center bearing. I got under the car (see above) and gave it an inspection. It doesn't seem to be the issue. Bessie II Link to comment Share on other sites More sharing options...
apexi Posted November 29, 2017 Share Posted November 29, 2017 Yeah I saw that you did a visual inspection but I wasn't sure if you grabbed it and checked for play. Link to comment Share on other sites More sharing options...
Enlight Posted November 29, 2017 Author Share Posted November 29, 2017 Yeah =T I rocked it up and down and left and right. The movement seemed normal to me and no metal on metal sounds. It could be the case that the movement that seems normal to me is not in fact normal. I based my assessment on other pictures of bushings I've seen that were completely torn. Mine looks practically new. Bessie II Link to comment Share on other sites More sharing options...
Max Capacity Posted November 29, 2017 Share Posted November 29, 2017 When the carrier bearing in my 05 wagon was going I felt a vibration when my right elbow rested on the consul. It was pretty obvious. The shafts move pretty easy when I grabbed them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Enlight Posted November 30, 2017 Author Share Posted November 30, 2017 When the carrier bearing in my 05 wagon was going I felt a vibration when my right elbow rested on the consul. It was pretty obvious. The shafts move pretty easy when I grabbed them. Did you end up replacing the shaft? Perusing the parts catalog it looks like the bearing itself is not serviceable. With a 6mt swap the Spec B drive shafts are pretty hard to come by in the salvage yards. Just dug up this thread you made an appearance in and it seems HAMMER DOWN likes the driveshaft shop. Bessie II Link to comment Share on other sites More sharing options...
Enlight Posted December 13, 2017 Author Share Posted December 13, 2017 When the carrier bearing in my 05 wagon was going I felt a vibration when my right elbow rested on the consul. It was pretty obvious. The shafts move pretty easy when I grabbed them. Just found your thread as well. I'm going to be removing mine this coming weekend and drop it off at Drive Line Service of NJ. Bessie II Link to comment Share on other sites More sharing options...
Enlight Posted December 17, 2017 Author Share Posted December 17, 2017 Continuing this and all future questions in my log Bessie II Link to comment Share on other sites More sharing options...
