Leftcoast_LGT Posted November 15, 2017 Share Posted November 15, 2017 I’m planning to get new wheels (RPF1s) and tires but I’m having a hard time deciding which what size to go with. The main thing I’m really wondering is, is there a difference in performance or handling between a 17x9 and a 18x8? And which will be easiest to fit? Here some additional info incase it matters 05 LGT Currently on stock wheels On konis and H&Rs Stage 3 Any feedback is greatly appreciated!! Link to comment Share on other sites More sharing options...
whitetiger Posted November 15, 2017 Share Posted November 15, 2017 talking about wheel width performance without any talk of what tire type or tire size you plan to run is pointless. what tires and size do you plan to run? Link to comment Share on other sites More sharing options...
jrho Posted November 16, 2017 Share Posted November 16, 2017 I would personally go 17x9 because I can't stand the convex face of rpf1s in a width less than 9". But like it's been said above, without tire information there really isn't much point in comparing performance. 17x9 will be lighter compared with an 18x8 though by a couple pounds each. Link to comment Share on other sites More sharing options...
Leftcoast_LGT Posted November 16, 2017 Author Share Posted November 16, 2017 talking about wheel width performance without any talk of what tire type or tire size you plan to run is pointless. what tires and size do you plan to run? 255/40/17. I havent looked into 18 inch wheels much yet, I was just recently told by my local Subaru shop that a 18x8 would be easier to fit than a 17x9 with my current suspension set up. I’d probanly go with 245/35/18 As far as tires, I’m pretty set on the firehawk Indy 500s Link to comment Share on other sites More sharing options...
whitetiger Posted November 16, 2017 Share Posted November 16, 2017 17x9 is hard to fit with that tire size. if you commit to that, be prepared for fender rolling/pulling and the need for after market camber adjustments to make it fit. 245/35/18 on a 18x8 +48 wheel will be much easier to fit, and wont give my much actual performance differences assuming equal tire compound on the street. If you are not traking/autoxing the car, stick with a 18x8 +48 and the 245/35/18 tire size. Link to comment Share on other sites More sharing options...
wesleyCrowbar Posted November 16, 2017 Share Posted November 16, 2017 17x9 won't fit unless you're running less than +40 offset with a koni setup, if memory serves correctly. Even with wheels that clear the struts, you'll need a decent pull/roll to get them to fit under the arches Link to comment Share on other sites More sharing options...
Leftcoast_LGT Posted November 17, 2017 Author Share Posted November 17, 2017 Thanks for the feedback! Just a thought.. Do you think I’d notice a difference in performance or handling between 17x8 and 18x8? Better acceleration? Link to comment Share on other sites More sharing options...
