Mouse Trouble
Looking for some help with what i believe is a dead mouse in the air vents. In the past i found a mouse nest in my cabin air filter and my wife swore she saw a mouse inside the car. I set some traps in the car for a couple of weeks but never caught anything. Fast forward a few months and monday I’m drive to work with the heat on and a really nasty smell which i assume is a dead mouse being warmed up by the heater which i why i assume it is in the vents somewhere.
So over the past 3-4 days i have pulled apart the car as much as i know how to find this dead mouse. Pulled apart the trunk and found mouse droppings. Pulled out the back seat and found a small nest and droppings. Took out the cabin air filter and that was clean and nothing in the blower. I pulled out the engine air filter and found nothing there. Took the cowl off and nothing in there. Stuck a bore scope in the dash vents and the vents under the front bucket seats as far As I could but didn’t see any dead mouse. Any other places i can look or any advice?
Thanks
You can pull the blower motor, its easy take about 15 minutes. Remove the panel under the glove box, three bolts and connector and the blower drops out.
Look up in there.
Engine Build - Click Here
