Stock 08 LGT Suspension
Guest
What suspension is on the 08 legacy gt stock? It looks like the back of my car is lowered but the front doesn't. Looked at it and its Bilstein, should I upgrade or is that good?
Original stock suspension uses KYB struts/shocks. The previous owner must have upgraded yours. You could have the Spec-B Bilsteins "take-offs" or the Bilstein HDs. For the springs, see if you can find a part number on them somewhere. The height difference, this is probably from the front strut mounts. For Bilsteins, you are supposed to use the Spec-B mounts. If the previous owner used the old mounts, they will not be the correct height.
What do you think of the suspension you have now? If you are happy with it, that's the main thing. One size does not fit all.
I would say that's normal. We call it saggy butt for a reason. A lot of japanese sedans do this, they cut the rear wheel arches lower then the front, the car will sit with 0 rake and still look like the rear end is sagging.
05 LGT 16G 14psi 290whp/30mpg (SOLD)
12 OBP Stock 130whp/27mpg@87 Oct
00 G20t GT28r 10psi 250whp/36mpg
22 Ascent STOCK
  • 4 weeks later...
My 08 sits low in the back too. Some 3/8" saggy butt spacers are the correct size to level the car.
