Tricks for putting on the turbo heat shield?!
There is a bracket that should be mounted to two of bolts on the turbo-downpipe connection, did you mount that? There are six or seven 10mm bolts all together. Did you break off any of the heat shield bolts? You can afford to lose one or two. When reinstalling the heat shield, I found it was easiest to secure the shield to the top bracket using two bolts as a first step. Don't tighten them down all the way yet. Now, go around and loosely put in the other 10mm bolts into place. Then, tighten them all down.
Even though you aren't installing an aftermarket heat shield, you use the pictures in this guide to show you the correct bolt and bracket locations.
http://www.grimmspeed.com/content/install_guides/heat_shield_subaru.pdf
Any tips on getting the bottom bracket around the downpipe?
Are you referring to the lower heat shield that is typically mounted on the downpipe? If it is the stock downpipe, a picture would help. When I went with an aftermarket downpipe, I just left it off.
Had the same issue. Use the image in this thread to see how to orient it and then bend the right, lower, rear corner about an inch upward. It will go right on with the pipe installed. Then bend back once in.
