subie bob Posted November 8, 2017 Share Posted November 8, 2017 Anyone have recommendations for obtaining a good short block for my 05 lgt. Also is anyone familiar with hms horizontal motor sport in oregon they seem to have some decent stuff Link to comment Share on other sites More sharing options...
Max Capacity Posted November 8, 2017 Share Posted November 8, 2017 EJ257, read my click here link in my sig. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
shralp Posted November 9, 2017 Share Posted November 9, 2017 $1700 shipped from Heubergers in Colorado is the cheapest you will find, (even though the Subaru west coast distribution center is right here in PDX!). Just had one shipped out. Horizontal Motorsports would be a decent choice, I just prefer the customer service and level of professionalism at Cobb Surgeline over by Bridgeport Link to comment Share on other sites More sharing options...
subie bob Posted November 9, 2017 Author Share Posted November 9, 2017 $1700 shipped from Heubergers in Colorado is the cheapest you will find, (even though the Subaru west coast distribution center is right here in PDX!). Just had one shipped out. Horizontal Motorsports would be a decent choice, I just prefer the customer service and level of professionalism at Cobb Surgeline over by Bridgeport Ill check them out hms is a bit pricey for what they have Link to comment Share on other sites More sharing options...
subie bob Posted August 21, 2018 Author Share Posted August 21, 2018 Ok so after my car has been sitting collecting dust for several months now im going to pull the engine and start the rebuild process ive found that it has a burnt valve on #2 and compression is low on #4. Ive decided to rebuild the short block myself i will be using manly rods with je pistons and rings. What i would like advice on at this point is what rod and main bearings and gasket kit should be used? Link to comment Share on other sites More sharing options...
boxkita Posted August 21, 2018 Share Posted August 21, 2018 Ynansb thread? Machine shop? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
subie bob Posted August 21, 2018 Author Share Posted August 21, 2018 (edited) Ynansb thread? Machine shop? ? ynansb thread Going through ssi in gladstone for machine work and head work Edited August 21, 2018 by subie bob Link to comment Share on other sites More sharing options...
apexi Posted August 22, 2018 Share Posted August 22, 2018 (edited) ynansb = you need a new shortblock It's something that has been said here so much that sometimes people will just use that acronym. There was member here named Mr. Tris that made a pretty long thread with lots of info on what to you should do, and what to expect when going through an engine rebuild. I don't know the details, but I think he got banned a few years ago, and his "ynansb" thread is gone too. I remember someone saved the post, and posted it again, but I can't seem to find that one either. Edited August 22, 2018 by apexi spelled tris's name wrong.. sorry dude. Link to comment Share on other sites More sharing options...
lockmedic Posted August 22, 2018 Share Posted August 22, 2018 I don't think you can do a proper rebuild of an EJ255/7 short block for less than what you can buy the brand new one for. You'll have $900-1200 in rods and pistons before you even take the crank and case halves to the machine shop. Link to comment Share on other sites More sharing options...
boxkita Posted August 22, 2018 Share Posted August 22, 2018 https://legacygt.com/forums/forumdisplay.php/engine-rebuild-threads-engines-only-142.html Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
subie bob Posted August 27, 2018 Author Share Posted August 27, 2018 I don't think you can do a proper rebuild of an EJ255/7 short block for less than what you can buy the brand new one for. You'll have $900-1200 in rods and pistons before you even take the crank and case halves to the machine shop. That is true but do they come with forged internals that can hold up for when i get a wild hair and i decided to add a bunch of other stuff? Im one of those that stock or a little above stock isnt good enough lol Link to comment Share on other sites More sharing options...
shralp Posted August 27, 2018 Share Posted August 27, 2018 If you don’t want to go OEM and need something to hold more power go with a stage 1 short block from IAG, they are $2900 and shipped to you in a returnable Pelican case... Link to comment Share on other sites More sharing options...
lockmedic Posted August 27, 2018 Share Posted August 27, 2018 The EJ257 short block everyone is buying is the one that comes in the STi. They're around 300hp in stock form and the conventional wisdom is they're good for around 450 without issue. If you're planning to go bigger than that . . . better save up for a 6 speed first. Keep in mind the car you're throwing all this money at is now and will always be a 2005. Link to comment Share on other sites More sharing options...
subie bob Posted August 27, 2018 Author Share Posted August 27, 2018 The EJ257 short block everyone is buying is the one that comes in the STi. They're around 300hp in stock form and the conventional wisdom is they're good for around 450 without issue. If you're planning to go bigger than that . . . better save up for a 6 speed first. Keep in mind the car you're throwing all this money at is now and will always be a 2005. 450 to 500 is around where im going to shoot for. My tacoma came in at 427 on the dyno it was alot of fun but it was just never enough for me and that was at the limit of the oem bottom end. so i figure if i build the bottom end to be able to handle whatever i decided to add to it later i wont have to worry about it then. And yes it is an 05 and will always be one but that is the one that i wanted and turned me over to the subaru side lol Link to comment Share on other sites More sharing options...
subie bob Posted August 27, 2018 Author Share Posted August 27, 2018 If you don’t want to go OEM and need something to hold more power go with a stage 1 short block from IAG, they are $2900 and shipped to you in a returnable Pelican case... Ive kinda had my eye on the stage 2 Link to comment Share on other sites More sharing options...
relative4 Posted August 27, 2018 Share Posted August 27, 2018 450 to 500 is around where im going to shoot for. You know there's a guy on the east coast selling a 500HP car for $5K, right? It'll take you at least $15K and months of work to get there with your existing car. Link to comment Share on other sites More sharing options...
boxkita Posted August 28, 2018 Share Posted August 28, 2018 You know there's a guy on the east coast selling a 500HP car for $5K, right? It'll take you at least $15K and months of work to get there with your existing car. I've been looking at that one too. Would be amazing to drive, cause a 300hp lgt is just a dog. My mind is staggered at being able to drift every corner at the track without effort. My run cost would be way higher than current. 500 is so old skool. 700 is the new number to have. Yeah, not helping, but 500 on a car designed for 250 seems absurd. The amount of upgrades needed to handle 300 is alot. Going to 500 requires so much more. Then again, maybe not. Cheap tires, cheap c/o, stoptech big brakes, iag stage 2, big turbo, hog-zaust, upgraded ice, led lights? you'd be all set for 15k depending on the deals you could score. It would handle ok because the cheap tires would insure you'd never be able to use it for most of the year (rains too much) and the rest of the time traffic is so bad you'd get on-ramps only. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
gkinslow Posted August 28, 2018 Share Posted August 28, 2018 You know there's a guy on the east coast selling a 500HP car for $5K, right? It'll take you at least $15K and months of work to get there with your existing car. link? Link to comment Share on other sites More sharing options...
boxkita Posted August 28, 2018 Share Posted August 28, 2018 link? Cars for sale. Find the highest views? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted August 28, 2018 Share Posted August 28, 2018 https://legacygt.com/forums/showthread.php/nh-2005-legacy-gt-limited-511awhp-270707.html Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
gkinslow Posted August 28, 2018 Share Posted August 28, 2018 Hell I didn't realize it was on the forum. But thanks for the spoon feeding. Link to comment Share on other sites More sharing options...
boxkita Posted August 28, 2018 Share Posted August 28, 2018 Hell I didn't realize it was on the forum. But thanks for the spoon feeding. All kinds of cool cars for sale on the forum. Check daily. I missed a bsm wagon by a month. :-( Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
