tonystark0007 Posted November 2, 2017 Share Posted November 2, 2017 wish one am replacing my manifold intake rigs gaskets so replacing does also do are cars benefits from the ts ones Link to comment Share on other sites More sharing options...
Max Capacity Posted November 2, 2017 Share Posted November 2, 2017 What ? I used stock when I did the ej257 over 5 years ago. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
tonystark0007 Posted November 2, 2017 Author Share Posted November 2, 2017 ok just want it to know if its worth it to get the torque solution tgv upper gasket vs stock one thanks bro Link to comment Share on other sites More sharing options...
Max Capacity Posted November 3, 2017 Share Posted November 3, 2017 Basically the only after market gasket to use is the Grimmspeed 2X 3" exhaust gasket for the down pipe. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
tonystark0007 Posted November 4, 2017 Author Share Posted November 4, 2017 thanks, bro thanks god i didn't spend the $ on that ill get stock ones Link to comment Share on other sites More sharing options...
Jaybird2013 Posted November 5, 2017 Share Posted November 5, 2017 You have a plastic IM, heat transfer is really not an issue. Stay with the oem upper and lower gaskets. Link to comment Share on other sites More sharing options...
