AC condenser leak - replace?
I noticed this last night, would I be correct in assuming that I need a new condenser? Or can this nylon plug on the bottom be tightened or something.. I know very little about AC systems.
I know this is definitely AC dye and not coolant as well, I've always used subaru blue coolant.
For now, I just cleaned the area up because I want to see how bad it's leaking.
Straighten and clean those fins while you're at it, the dirtier that thing is, the harder your AC has to work to do the same job. I use this stuff diluted in a pump sprayer on my intercooler, radiator, and condenser once a year. I also use it on my home AC. It's pretty easy to use if you follow the directions.
https://www.amazon.com/Nu-Calgon-Inc-429108-Nu-Brite-1-Gallon/dp/B00ECV4D38
