Ironworker613 Posted October 27, 2017 Share Posted October 27, 2017 Has anyone used the rev9 turbo inlet from ebay? And if so how is it? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 27, 2017 Share Posted October 27, 2017 Why do you think you need that ? The stock intake is good until your making over 350AWHP. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 28, 2017 Share Posted October 28, 2017 I have one and I had to trim about 2 1/2" off for my intake to fit I probably could of did 3" very tight fit under the intake manifold. Link to comment Share on other sites More sharing options...
Ironworker613 Posted October 28, 2017 Author Share Posted October 28, 2017 Because my stock inlet is torn at the turbo. Link to comment Share on other sites More sharing options...
covertrussian Posted October 29, 2017 Share Posted October 29, 2017 Why do you think you need that ? The stock intake is good until your making over 350AWHP. Because my stock inlet is torn at the turbo. Don't mind Max, he thought you were asking about Intakes and not inlets. Inlet failure is more common then wheel bearing failure on Subaru's What year is your car? That inlet is for 07+, which has the BPV connection further from the turbo, requiring you to stretch your BPV hose quite a bit. I would almost say it's easier to retrofit a WRX/STI inlet then trying to fit the 07+ inlet. 05 LGT 16G 14psi 290whp/30mpg 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg Link to comment Share on other sites More sharing options...
MilesA Posted October 29, 2017 Share Posted October 29, 2017 I think the later model WRX OEM inlet (for EJ engines) is an improved design compared to ours and should fit OK. Link to comment Share on other sites More sharing options...
relative4 Posted October 29, 2017 Share Posted October 29, 2017 You can use an '07+ inlet without TOO much trouble if you just get an '07+ bypass hose. That said, I found the aftermarket inlets totally not worth the trouble. Sure, the OEMs tear, but much easier to buy a new one of those every 5-10 years than to shoehorn a silicone monstrosity under the manifold. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 29, 2017 Share Posted October 29, 2017 https://www.amazon.com/gp/product/B01M7R1IIB/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 That's the one I got I got a BPV hose from a '08 Forester XT it was hard getting the hose on to the inlet but had I taken off the intake manifold I would of had no problem but I did not want to do all that. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 29, 2017 Share Posted October 29, 2017 It may be easier to lift the intake manifold at the TGV's to head. That way you can leave the fuel lines attached. It's a lot of work either way. You just need to raise it a little to give you enough room. Also make sure you have the new larger orange o-rings between the manifold and TGV's, you can see the color at that joint. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bergs Posted October 29, 2017 Share Posted October 29, 2017 It's a bit over an hour to pull the intake manifold with TGV's attached. For the turbo inlet, probably around the same amount of time to loosen the manifold and R/R the inlet. OEM replacement is what I went with. Too many variables with aftermarket in this particular case. Link to comment Share on other sites More sharing options...
Ironworker613 Posted October 29, 2017 Author Share Posted October 29, 2017 I have an 07 spec b, and I had to remove the manifold to do the gaskets that were leaking. You can remove the manifold without taking the fuel lines out by cutting a slot in between the two bolt holes on the drivers side. Link to comment Share on other sites More sharing options...
Phate Posted October 30, 2017 Share Posted October 30, 2017 I have one and I had to trim about 2 1/2" off for my intake to fit I probably could of did 3" very tight fit under the intake manifold. I mean you have to trim a decent bit off of pretty much any silicone inlet. I trimmed a bit off my AVO, and it wasn't enough. I haven't gotten around to trimming more off because I don't feel like taking things apart again, and have just been dealing with having a kinked aftermaf hose. I'll sort it all out when I put the VF52 on the car. If I had to guess, the AVO probably requires a good inch, inch and a half or so to be trimmed off. Link to comment Share on other sites More sharing options...
covertrussian Posted October 30, 2017 Share Posted October 30, 2017 I had 0 issues installing the Perrin STI inlet, it slid right in. Had to use a screw driver to prop it up on the turbo end (and to get the silicon aligned with the turbo, besides that wasn't that bad. I think the issues come from trying to fit a 3" inlet, which is an overkill for stock sized turbos anyway. 05 LGT 16G 14psi 290whp/30mpg 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg Link to comment Share on other sites More sharing options...
Merc6 Posted October 31, 2017 Share Posted October 31, 2017 I mean you have to trim a decent bit off of pretty much any silicone inlet. I trimmed a bit off my AVO, and it wasn't enough. I haven't gotten around to trimming more off because I don't feel like taking things apart again, and have just been dealing with having a kinked aftermaf hose. I'll sort it all out when I put the VF52 on the car. If I had to guess, the AVO probably requires a good inch, inch and a half or so to be trimmed off. The fun I will have when it's my turn with my AVO. What's the way to see if it's too long if the engine were already out and on a stand? 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
MilesA Posted October 31, 2017 Share Posted October 31, 2017 Maybe measure the stock one and add a small margin of safety since you can only cut once if you go too short. Link to comment Share on other sites More sharing options...
Merc6 Posted October 31, 2017 Share Posted October 31, 2017 Maybe measure the stock one and add a small margin of safety since you can only cut once if you go too short. LOL I could have thought of that, hoping the tear, 52 instal and possible shrinkage over the years may change the outcome. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Ironworker613 Posted October 31, 2017 Author Share Posted October 31, 2017 Well I got it installed, it wasn't easy. Even with removing the manifold, its hard to believe how much they crammed into such a small area! I had to trim about a 1/4" on an angle on the turbo end. I had an even harder time getting the perrin tmic bolted up! Link to comment Share on other sites More sharing options...
MilesA Posted October 31, 2017 Share Posted October 31, 2017 LOL I could have thought of that, hoping the tear, 52 instal and possible shrinkage over the years may change the outcome.Just having a Captain Obvious moment here. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 31, 2017 Share Posted October 31, 2017 Only reason I got this was because my AVo had a tear at the turbo inlet and it was missing the metal insert for the BPV on the inlet and the metal ring for the filter end.. the last owner just stuck a wooden stick in the BPV opening. I had some nasty compressor surge but it feels so nice to hear my BPV venting back into the intake. Link to comment Share on other sites More sharing options...
