Swiftwind Posted October 23, 2017 Share Posted October 23, 2017 I drive a 2015 premium 2.5 (mid tier) Subaru legacy. The gear shift indicators for drive and manual are no longer backlit. I was wondering, am I looking at just replacing a fuse or do I need to take it apart to replace the bulb/LED out? Thank you for your time!! Link to comment Share on other sites More sharing options...
mwlegltd Posted October 23, 2017 Share Posted October 23, 2017 warranty? Link to comment Share on other sites More sharing options...
Swiftwind Posted October 23, 2017 Author Share Posted October 23, 2017 warranty? To be honest I'm not sure if it's covered but I'll ask. Link to comment Share on other sites More sharing options...
ammcinnis Posted October 23, 2017 Share Posted October 23, 2017 To be honest I'm not sure if it's covered ... It's covered in the base 3 year/36,000 mile warranty. It would also be covered by a Subaru Added Security Gold Plus service plan. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Gravy Posted October 27, 2017 Share Posted October 27, 2017 I have the same problem. Curious if anyone here has replaced any of the shift indicator lights. Not finding anything using search. Link to comment Share on other sites More sharing options...
MaseDoGG Posted October 28, 2017 Share Posted October 28, 2017 Can someone confirm the M-D are supposed to e illuminated? Mine are not. Just got the car and noticed this Link to comment Share on other sites More sharing options...
Gravy Posted October 28, 2017 Share Posted October 28, 2017 Now that I think of it, I can't remember if my M-D was ever illuminated. I just noticed that they weren't and assumed the bulb needed to be replaced. Would appreciate confirmation as well before I go and rip out the center console Link to comment Share on other sites More sharing options...
PATS4LIFE Posted October 28, 2017 Share Posted October 28, 2017 Now that I think of it, I can't remember if my M-D was ever illuminated. I just noticed that they weren't and assumed the bulb needed to be replaced. Would appreciate confirmation as well before I go and rip out the center console Yes it’s lit up. Link to comment Share on other sites More sharing options...
Gravy Posted October 29, 2017 Share Posted October 29, 2017 Thanks! Link to comment Share on other sites More sharing options...
MaseDoGG Posted October 29, 2017 Share Posted October 29, 2017 Mine is illuminated when in park but not when in D Is yours the same ? Link to comment Share on other sites More sharing options...
Gravy Posted October 29, 2017 Share Posted October 29, 2017 Nope, mine is dark in both modes. Link to comment Share on other sites More sharing options...
chowser51 Posted October 29, 2017 Share Posted October 29, 2017 Mine only come on if the headlights are on Link to comment Share on other sites More sharing options...
Gravy Posted October 29, 2017 Share Posted October 29, 2017 Yep - my P, R, N illuminate in synch with the headlights. However my M-D lights do not. Now searching for instructions on R&R'ing the shift-lever cover and replacing the bulbs. Link to comment Share on other sites More sharing options...
Jsmith Posted October 30, 2017 Share Posted October 30, 2017 Mine lights up whenever the headlights are on, no matter which position the shifter is in. Tested this last night after reading through this thread. Link to comment Share on other sites More sharing options...
tornichoe Posted October 30, 2017 Share Posted October 30, 2017 Yep - my P, R, N illuminate in synch with the headlights. However my M-D lights do not. Now searching for instructions on R&R'ing the shift-lever cover and replacing the bulbs. If you do remove the shift knob, can you do a small write up? I've found removal instructions for all different auto transmissions but couldn't find anything specific for the 15-17 legacy/OB. Link to comment Share on other sites More sharing options...
Gravy Posted October 30, 2017 Share Posted October 30, 2017 I found this over on subaruoutback.org . Here is a link to the pdf instfructions. I haven't tried it yet, but will update with my experience. Looks pretty straightforward, but not sure how the clips work. Link to comment Share on other sites More sharing options...
Fiatz79 Posted October 31, 2017 Share Posted October 31, 2017 Mine lights up whenever the headlights are on, no matter which position the shifter is in. Tested this last night after reading through this thread. Mine are lit with the headlights as well. Lighting Mods Low Beams: D4S - OSRAM XENARC 66440 CBI HID BULBS Highbeam/DRL: 9005 - OSRAM NIGHT BREAKER UNLIMITED 9005NBUHCB BULBS Fog: H11 - OSRAM NIGHT BREAKER UNLIMITED 64211NBU-01B BULBS Subaru 20mm RSB Link to comment Share on other sites More sharing options...
tornichoe Posted October 31, 2017 Share Posted October 31, 2017 I checked mine today and the M-D does not light up in any position. Headlights ON with shift lever in any position. The other 3 P, R and N do light up red. Don't know if this is something that got added after a certain production batch... Never cared much if it was lit or not. May be I'll bring it up the next time I go to the dealer. Link to comment Share on other sites More sharing options...
MaseDoGG Posted November 8, 2017 Share Posted November 8, 2017 The M-D should be illuminated with the other letters. I took it to the dealership and they’re fixing it under warranty Link to comment Share on other sites More sharing options...
Gravy Posted November 8, 2017 Share Posted November 8, 2017 Thanks MaseoGG, I have a '15 as well - but I assumed this issue wouldn't be included under warranty. Link to comment Share on other sites More sharing options...
securityguy Posted November 8, 2017 Share Posted November 8, 2017 Thanks MaseoGG, I have a '15 as well - but I assumed this issue wouldn't be included under warranty. Why would you assume that your warranty wouldn't cover it? That's what your warranty is for. Link to comment Share on other sites More sharing options...
Boobaroo Posted November 10, 2017 Share Posted November 10, 2017 I had the same problem; it was covered under warranty. The lighting elements can be replaced. Link to comment Share on other sites More sharing options...
MaseDoGG Posted November 10, 2017 Share Posted November 10, 2017 The replaced my whole PRND-M set up they said. Link to comment Share on other sites More sharing options...
Swiftwind Posted November 10, 2017 Author Share Posted November 10, 2017 I totally missed the notifications for this thread. Weird. I'll take it this weekend. Link to comment Share on other sites More sharing options...
Gravy Posted November 10, 2017 Share Posted November 10, 2017 Why would you assume that your warranty wouldn't cover it? That's what your warranty is for. I have 58k miles, assumed that this would only be covered within the 36k warranty. I'll take it to the dealer and see if this is covered. Link to comment Share on other sites More sharing options...
