EVAP leak
Need some help here. I have a 2013 Subaru legacy 2.5i premium. Recently the check engine light turned on, and the brake light and cruise control light started blinking. The car feels fine when I drive it, but cruise control no longer works. Just one code is coming back and it's for an EVAP leak. Had the seal replaced, the sensor replaced, and when that didn't work a smoke test done. But the smoke test found no leak. What else could be the issue?
Sent from my XT1585 using Tapatalk
What's the code? I think there are a couple depending on the size of the leak.
If it's a small leak, the gas cap would be a good place to start looking (unless that's the seal you were referring to).
P0445, so large leak. And yeah, I did mean the gas cap when I mentioned replacing a seal.
