Duceanahalf Posted October 14, 2017 Share Posted October 14, 2017 2005 LGT with 5EAT Drove about 20 miles last night, parked for about 20 minutes and restarted, made it a block or two and noticed a CEL and flashing cruise. Car drove normally and started fine, used the fuse box diagnostic connector to pull P0700 tcu code P0817 park sensor switch c0108 left front wheel speed sensor fault I can still use sport mode and manually shift No other faults or indicator lights I checked the fuse under hood and it's good Anything else to check? Or just clear the codes and see what happens? Link to comment Share on other sites More sharing options...
relative4 Posted October 14, 2017 Share Posted October 14, 2017 Neither of those is potentially harmful, so clearing is a good place to start. I've had very similar codes to both of those pop once and never return. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 14, 2017 Share Posted October 14, 2017 left front WSS may be something you want to have a look at. Has that hub/bearing been replaced ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Duceanahalf Posted October 14, 2017 Author Share Posted October 14, 2017 left front WSS may be something you want to have a look at. Has that hub/bearing been replaced ? Yeah, i replaced it a few months ago,. I was gonna pull the wheel and see if i can see any obvious damage. Is there a way to sltest the sensor? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 15, 2017 Share Posted October 15, 2017 There are only a few front hubs that work on these cars, most don't work. http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238p5.html post 162. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Duceanahalf Posted October 15, 2017 Author Share Posted October 15, 2017 Started it a few times and the lights have turned off Link to comment Share on other sites More sharing options...
