Whopper Posted October 8, 2017 Share Posted October 8, 2017 So recently my car started stalling/stuttering at 5psi of boost. I cant find the problem. I thought it was the fact that I deleted the evap system and some pressure sensors but when I put it back in it still happened. My ABS light keeps coming on to so I thought maybe it was a maf sensor problem but I tested it and its all fine. My battery keeps dyeing so I think It might be a low voltage problem with the spark plugs but that dosent make to much sense because it only happens at boost not at any certain rpm. I tested all the spark plugs and wire to make sure they where firing. I dont think I have any major boost leaks because vacuum seems fine and its always at the exact same spot on my boost gauge. I'm think maybe a fuel mixture issue or a o2 sensor failure. I tried reading my check engine light but all the codes just go to evap stuff. Any help. Link to comment Share on other sites More sharing options...
wtdash Posted October 13, 2017 Share Posted October 13, 2017 1. Get your battery/alternator fixed. 2. Post your codes (all of them). 3. Exactly what did you remove? I thought it was the fact that I deleted the evap system and some pressure sensors but when I put it back in it still happened. The pressure sensors are part of the turbo's ECU tuning. Link to comment Share on other sites More sharing options...
doublechaz Posted October 14, 2017 Share Posted October 14, 2017 I'm wondering why the evap delete? Link to comment Share on other sites More sharing options...
Setnev Posted October 14, 2017 Share Posted October 14, 2017 I'm wondering why the evap delete? Because Racecar! Link to comment Share on other sites More sharing options...
MilesA Posted October 14, 2017 Share Posted October 14, 2017 I'm wondering why the evap delete?The air is way too clear, we need more smog. Yay hydrocarbon fumes! Link to comment Share on other sites More sharing options...
Setnev Posted October 14, 2017 Share Posted October 14, 2017 The air is way too clear, we need more smog. Yay hydrocarbon fumes! Sounds like an electric car or a hybrid is in your future, Miles Link to comment Share on other sites More sharing options...
doublechaz Posted October 14, 2017 Share Posted October 14, 2017 I'm goin to eliminate the right rear wheel to save weight. I don't know why they put that crap on there in the first place. Totally not needed unless you're towing or something. Link to comment Share on other sites More sharing options...
Setnev Posted October 15, 2017 Share Posted October 15, 2017 I'm goin to eliminate the right rear wheel to save weight. I don't know why they put that crap on there in the first place. Totally not needed unless you're towing or something. Dude everyone knows you delete the front right wheel. Link to comment Share on other sites More sharing options...
RustyRuu Posted October 17, 2017 Share Posted October 17, 2017 Sounds like an electric car or a hybrid is in your future, Miles the new NSX is pretty sweet though Link to comment Share on other sites More sharing options...
Whopper Posted October 18, 2017 Author Share Posted October 18, 2017 Fixed it: All the censors connected to the evap system i installed along with a stock boost controller. Link to comment Share on other sites More sharing options...
