nzsubsub Posted October 4, 2017 Share Posted October 4, 2017 Hi all, I wanted to test how this would work. If I unlock the door with the emergency key without pushing the unlock button on the remote, the alarm goes off. All the instructions I've read are just basically 1. Open door with key 2. Hold key fob up to start button for a few second 3. Push start button to start car like normal but the opening door with key part sets the alarm off Edit* Ok, so if you arm the car with the fob then it's going to go off apparently. However, there must be a way to turn the alarm off if you use a key to unlock? Also, is there anyway to disable the alarm completely? Link to comment Share on other sites More sharing options...
nzsubsub Posted October 5, 2017 Author Share Posted October 5, 2017 Nothing? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 5, 2017 Share Posted October 5, 2017 What's the owners manual say ? You can get a replacement battery at most any store. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
nzsubsub Posted October 5, 2017 Author Share Posted October 5, 2017 What's the owners manual say ? You can get a replacement battery at most any store. I don't have an owners manual and if I did, I can't read Japanese (should have clarified this is a JDM model). I know about replacing the battery. What I'm asking is that in the scenario where I locked\armed the car with the remote, how could I turn the alarm off after unlocking the door with the key. Link to comment Share on other sites More sharing options...
nzsubsub Posted October 5, 2017 Author Share Posted October 5, 2017 The manuals I've found on the internet all show an ignition. Mine is push button. Link to comment Share on other sites More sharing options...
Scottydunno Posted October 8, 2017 Share Posted October 8, 2017 The manuals I've found on the internet all show an ignition. Mine is push button.Most times, if you cycle the key in the door from unlock to lock and back, it should disable the alarm. Also, sometimes starting the car while alarm is active will shut it off as well. Most of my lockouts (tow truck operator) end up in this scenario even with a dead key fob. Sent from my SM-G920P using Tapatalk Link to comment Share on other sites More sharing options...
sshole Posted October 8, 2017 Share Posted October 8, 2017 Subaru's alarm is dumb and always goes off if you unlock and open the door by physically inserting your key into the keyhole. The alarm should turn off once the car is started. Link to comment Share on other sites More sharing options...
nzsubsub Posted October 9, 2017 Author Share Posted October 9, 2017 Will try a couple of things and report back Link to comment Share on other sites More sharing options...
