2008 Legacy GT - tapping noise on decel
Trying to get some ideas on what I'm hearing....and yes, a mechanic has checked it out.
A few details:
All stock
The performance is sluggish/ hesitation under hard accel
Engine tapping noise seems to be only on decel
Sounds fine when cold however I have not run it above 3k until it is warmed up
No CEL
Could one of the lifters be failing? This is clearly a tap not a knock.
Might be a sticky valve or valves. Subaru makes a top end engine cleaner that is introduced into the manifold through a vacuum hose (as for the brake booster), called Subaru SA459. It would do no harm to try it and see if your issue improves.
Curious if you can hear this noise when the car is stationary, if it is revved up and allowed to go back to idle? If so, you could put a vacuum gauge on it. That would give you a bit more insight into what's going on. If you have the FSM, there are instructions for doing this test and interpreting the vacuum gauge readings.
Could be your fuel line dampers going bad. Happened to me this summer. Luckily, each damper only costs around $30-$40 OEM (there are two: a feed and return line damper).
I was getting an annoying tap/knocking sound at lower RPMs. You can use the screwdriver-to-ear trick to listen to your dampers and find out if they're making the noise.
It seems to occur only when warm and I have not tried to free rev the engine. My mechanic friend offered a time donation so he didn't go shoulder-deep in diagnosis. He basically said "run it".
When I grab the parts for my 2005, I'll also be picking up a can of top end cleaner. I'm guessing it's going to be a similar process to Seafoam.
...When I grab the parts for my 2005, I'll also be picking up a can of top end cleaner. I'm guessing it's going to be a similar process to Seafoam.
Pretty similar process, it comes in a aerosol can and is sprayed slowly into the vacuum port on the intake manifold normally used by the brake booster. It's approved by Subaru for their engines.
Do you have BtSSM? It might give you a few clues about the issue if you were monitoring while driving around.
No BtSSM and not a whole lot of desire to give banking information to Google Play. If there's a way around that tiny detail then I'm all ears. It'd certainly be a nice tool to have.
jcaroth - Thank you for the suggestion. I'll check the fuel dampers as well.
You can set a payment method in Google Play to accept Paypal or Debit card. Not very different from other online purchases except, of course, dealing with Big Brother. ;)
