rodviar Posted October 1, 2017 Share Posted October 1, 2017 Hi! I have had my 2012 Subaru Legacy for a few months and I love it! However, I recently discovered that below the steering wheel, there is a loose plug that is not connected to anything. Everything in the car seems to work just fine, but I am curious about what that part should be plugged into. Click here to view image of the loose plug. Any help would be greatly appreciated! Link to comment Share on other sites More sharing options...
cww516 Posted October 1, 2017 Share Posted October 1, 2017 That's the OBD2 connector, which is where you'd plug in a diagnostic tool to read codes and such. Link to comment Share on other sites More sharing options...
FLlegacy Posted October 2, 2017 Share Posted October 2, 2017 That's the OBD2 connector, which is where you'd plug in a diagnostic tool to read codes and such. I was hoping this was a joke...guess not! Welcome to Subaru, yes that would be the obd2 port, if you look under any dash of all cars made after 1995 you will find that exact port, most are black in color. https://www.google.com/search?q=obd2+port&rlz=1C1CHFX_enUS493US493&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjC27aA4dDWAhUE72MKHeiUAOwQ_AUICygC&biw=1366&bih=637 Link to comment Share on other sites More sharing options...
rodviar Posted October 2, 2017 Author Share Posted October 2, 2017 That's the OBD2 connector, which is where you'd plug in a diagnostic tool to read codes and such. Lol! Can you tell I know NOTHING about cars?? Thank you for taking the time to answer... I learned something today! Link to comment Share on other sites More sharing options...
nads Posted October 3, 2017 Share Posted October 3, 2017 Define loose. It should be rigidly mounted. Link to comment Share on other sites More sharing options...
FLlegacy Posted October 3, 2017 Share Posted October 3, 2017 Mine is not terribly rigid, the panel it is in flexes quite a bit. Link to comment Share on other sites More sharing options...
nads Posted October 3, 2017 Share Posted October 3, 2017 Mine is not terribly rigid, the panel it is in flexes quite a bit. I guess as rigid as the member they are bolted too but it shouldn't be tee bag'n the lower dash. Link to comment Share on other sites More sharing options...
rodviar Posted October 9, 2017 Author Share Posted October 9, 2017 My apologies for the late reply. The bolts that attach the obd2 port to the lower dash are definitely missing... so the port is basically just hanging by where the pedals are. As a temporary fix, I have used zip ties to connect the port and the lower dash but I'd like to find a more permanent solution. Any suggestions as to where I can get those bolts/pieces would be appreciated! Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted October 9, 2017 Share Posted October 9, 2017 Mine is not terribly rigid, the panel it is in flexes quite a bit. I actually thought they were missing a screw or something because it was so flexible Link to comment Share on other sites More sharing options...
GTEASER Posted October 9, 2017 Share Posted October 9, 2017 The port itself snaps into the opening on the lower vanity panel toward the left side near the hood pop latch. The lower vanity panel attaches to the lower portion of the dash with 2 or 3 pop-its. Is the lower vanity panel hanging? It is not really attached rigidly to the lower dash, bit it is enough to support he weight of the OBDII plug. Can you post a pic? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
