rebourne Posted June 17, 2021 Share Posted June 17, 2021 I was just about to reply with what setup I'm planning to mount when I glanced at your account and realized .....You're who I bought it from! HaHa Small world! Too funny! Welcome! I still lurk and post on here occasionally. The online Outback world is small! pic thread build thread Link to comment Share on other sites More sharing options...
Rhitter Posted June 22, 2021 Share Posted June 22, 2021 Something else to just be aware of - you will get tire rub. I went down to Legacy GT height and one tire rubbed. Nothing else did, but occasionally one of my tires rubbed. I had many alignments and it was always that one tire. If you load up the back with people+ gear your rear wheels will occasionally rub. I settled on + 1 inch front and +1.5 inches rear from Legacy GT height to still use my outback as an outback (stiffer springs would have worked also). Rebourne also used his as an Outback - but I think he went to smaller OD tires. My OBXT build Link to comment Share on other sites More sharing options...
rebourne Posted June 22, 2021 Share Posted June 22, 2021 Oh, if you have not already found this in your research, the OBs have the exact same inner fender liners and fenders as a Legacy (I type LGT for short, but same for all 4th gen Legacies), yet the OBs have a taller diameter tire. I had mine fenders rolled when i got the Tein springs and Koni's down to below LGT height. Then I had it rolled again (MOAR!) when i went to 245s. It always found a place to rub, but only at extreme angles, which meant I had found the right tire size ;-) When I briefly ran LGT diameter tires, all was good. https://legacygt.com/forums/showpost.php?p=5223264&postcount=30 pic thread build thread Link to comment Share on other sites More sharing options...
kortina Posted August 1, 2021 Share Posted August 1, 2021 (edited) Installed tbSTi Bilstein's with pink springs. LGT Control arms and Whiteline KCA399 going in tomorrow. https://drive.google.com/file/d/1fsC6dWOhfwmfuWdsTok8dBPwoBhwmeGZ/view?usp=sharing H6, Raptor Headers, 5EAT, 100k (km). Edited August 1, 2021 by kortina add image Link to comment Share on other sites More sharing options...
rebourne Posted August 5, 2021 Share Posted August 5, 2021 Installed tbSTi Bilstein's with pink springs. LGT Control arms and Whiteline KCA399 going in tomorrow. https://drive.google.com/file/d/1fsC6dWOhfwmfuWdsTok8dBPwoBhwmeGZ/view?usp=sharing H6, Raptor Headers, 5EAT, 100k (km). So clean! Paint and body look so good. pic thread build thread Link to comment Share on other sites More sharing options...
Claw Posted August 12, 2021 Share Posted August 12, 2021 Oh, if you have not already found this in your research, the OBs have the exact same inner fender liners and fenders as a Legacyhttps://legacygt.com/forums/showpost.php?p=5223264&postcount=30 I didn't find this to be the case, the 05 OB had a different mudguard position when I went to Pick'n'Pull to grab a front fender to replace my 05 LGT fender liner. Link to comment Share on other sites More sharing options...
connoisseurr Posted December 10, 2021 Share Posted December 10, 2021 The V1 and V2 threads have been tremendously helpful that I very much love my n'used OBXT - but it needs some lowering. I'm looking for stock LGT height that will hold up some weight when I plan to actually use the Outback. No towing, just hauling stuff - so definitely don't want a setup in the rear that will sag. With that said, I'd like to go with Bilstein B6 struts/shocks for front and rear. Looks like I'll need the Spec.b hats for fitment and adjustable control arms to dial everything in. Looking for spring and spacer recommendations. Photos would also be a bonus! Again, looking for close to stock LGT height as I'd like to run an 18" with meaty tires. Link to comment Share on other sites More sharing options...
rebourne Posted December 10, 2021 Share Posted December 10, 2021 King rear springs? https://get-primitive.com/springs/550-king-springs-2005-2009-outback-standard-height-rear-only.html?search_query=springs&results=11 hrmm... i don't see LGT height King springs with their stiffer rate. I think you're going to find stiffer rear springs with dedicated coil overs. Definitely don't go with Tien H-tech. I had major rear sag with those when loaded up for trips, or even just costco. pic thread build thread Link to comment Share on other sites More sharing options...
connoisseurr Posted December 10, 2021 Share Posted December 10, 2021 King rear springs? https://get-primitive.com/springs/550-king-springs-2005-2009-outback-standard-height-rear-only.html?search_query=springs&results=11 hrmm... i don't see LGT height King springs with their stiffer rate. I think you're going to find stiffer rear springs with dedicated coil overs. Definitely don't go with Tien H-tech. I had major rear sag with those when loaded up for trips, or even just costco. I'll give Primitive a call to see if they have anything. Something I'm now trying to figure out is if the USDM (aftermarket) Bilstein B6 have a similar higher spring perch as do the JDM Bilsteins... Bilstein's catalog calls out the need for Spec.b hats for both front and rear. Anyone know? Link to comment Share on other sites More sharing options...
KevinEdgar Posted December 13, 2021 Share Posted December 13, 2021 1 Link to comment Share on other sites More sharing options...
RumblyXT Posted December 21, 2021 Share Posted December 21, 2021 These cars on their stock suspension look pretty high from outside, but once you're driving, they feel quiet low to the ground. Can't imagine with a lowered suspension 1"-2" reducing the fender gap they must feel really really low. I'm used to my older Forester which sat a bit higher.. Link to comment Share on other sites More sharing options...
Febreze Mee Posted August 2, 2022 Share Posted August 2, 2022 Photos from the Cascade Loop Rally in mid-June. 4 MILKRUN - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 3, 2022 Share Posted August 3, 2022 Very nice! 1 Link to comment Share on other sites More sharing options...
robbenfred50 Posted October 23, 2022 Share Posted October 23, 2022 Love it Link to comment Share on other sites More sharing options...
Abelr Posted December 3, 2022 Share Posted December 3, 2022 The commuter 3 Link to comment Share on other sites More sharing options...
Febreze Mee Posted December 4, 2022 Share Posted December 4, 2022 13 hours ago, Abelr said: The commuter One of my favorite colors. MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Febreze Mee Posted December 4, 2022 Share Posted December 4, 2022 HWY 20 Pics 3 MILKRUN - Click Here Link to comment Share on other sites More sharing options...
