Need pads, thinking of getting new rotors
I need new pads and my rotors are okay, but old so thinking of replacing. I just use it as my daily driver so I don't "need" anything special. Although drilled and slotted do look better. Any good bang for my buck pads/rotors I should go looking for? Not looking to go spend big money on super high performance parts since I don't drive with a need for them, but I don't want to buy garbage either. Seen eBay has slotted and drilled random brand stuff for under $200 but guessing those aren't worth buying even for my daily driving.
You don't really need drilled and slotted. That's mostly for looks. You can benefit from fresh rotors, though. Centric Premium rotors are pretty inexpensive if you shop around. They are a good value.
I've been running the cheapest centric blank rotors for years in a few cars, never had any problems with them. I'm talking about the ones that cost like $40-50 a piece for the fronts :lol: I even find they don't get as much brake shudder as the OEM rotors in a couple of cars.
Centric has a few different rotor offerings. The Premiums cost about 1/3 more than the basic ones. Premiums are supposed to be similar to the OEM rotors and machined to a higher standard. They have a black anti-rust coating on the top hat area.
I recently, will back in early May put NAPA cheap rotors on, and have been liking them ever since. Next time, I get the ones that are painted.
Engine Build - Click Here
I'm not happy with the noise the slotted rotors make on the front of my Spec B, during braking. There is a hummm. Where the non-slotted NAPA rotors on the wagon make no noise.
I was thinking about getting slotted rotors this time.. so you telling me they are worthless to buy?
As long as your brakes can lock up your tires, the most cost effective braking upgrade you can make is better tires. Most of the slotted rotors you see are cosmetic upgrades.
I run quality tires myself and noticed a major change. Now it's time to out new pads and rotors. Bit of steering wheel shake when I brake. That being said my driver side rear wheel barring is bad and being replaced this weekend. Could that be causing my wheel wobble and not warped rotors?
I'd say not so much. Cheap pads won't clean the brake dust off of them under braking. I find Hawk ceramic pads work pretty well at self cleaning.
...That being said my driver side rear wheel barring is bad and being replaced this weekend. Could that be causing my wheel wobble and not warped rotors?
Bad wheel bearings usually cause a roaring noise, sometimes a grinding noise if they're in really bad shape. The noise gets louder driving through curves.
New rotors and pads will probably take care of the shaking. Make sure that you clean and lube the caliper sliding pins. Use the right grease, such as Sil-Glyde, on the pins.
I've done several tests with pads and here's my cliff note review:
Hawk pads: Great pads, low dust, pricey
StopTech: Excellent pads, very dusty, good price
Power Stop Evolution: Same as Hawk pads, low price.
I have been running Power Stop for several years now on all my vehicles. It's the bang for the buck if you're on a budget.
My wife's balls are delicious.
OP, I see your car is over 10 years old.
You may want to think about replacing the calipers. I did this a few month's back on both my cars. Very glad I did. I used NAPA rebuilt calipers, just make sure you open the box and make sure all the parts are there before you leave the store. Also make sure the sealing surface for the banjo bolt washer is flat.
Most auto parts stores can get a replacement in 2 hours in my area. I had to get three calipers before everything was right. NAPA even delivered the last one to my house.
If I had bought these from an on-line store, I'd have spent lots of time waiting for parts.
These cars are pretty easy to replace the calipers and bleed the brake system.
Saw on one of the forums that steering wheel shaking was actually due to the calipers rather than the disc/rotor.
It can be due to several things, glazed rotors, uneven pads, sticky calipers, LCA bushings...etc. It's one of those things that you have to inspect all parts associated with it.
