dawkins20 Posted August 21, 2017 Share Posted August 21, 2017 Title says it all, my 2011 Legacy GT just had it's first CEL. Appears to be running fine otherwise. I checked the gas cap first and it seemed tight. I have a V2 AP which is unmarried at the moment. I wanted to know if it's possible to check or clear the CEL with this . If I remember correctly , marrying it would flash the ECU ,and therefore make the code dissapear before I could see what it is. Link to comment Share on other sites More sharing options...
FLlegacy Posted August 21, 2017 Share Posted August 21, 2017 Take it to an AutoZone or advance and ask them to pull the code for you. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
cww516 Posted August 21, 2017 Share Posted August 21, 2017 You should be able to. I was able to get to the appropriate screen with my V3 plugged into my Baja- didn't show me anything, but I was able to get to the code reader function. Link to comment Share on other sites More sharing options...
dawkins20 Posted August 21, 2017 Author Share Posted August 21, 2017 Ok cool. Will try it when I get home or will hit AutoZone if it doesn't work Link to comment Share on other sites More sharing options...
