FrankNature Posted August 21, 2017 Share Posted August 21, 2017 If I change the plugs and the coil pack, would it be stupid to replace the wires while I'm at it ? Also what are the recommended spark plugs I should go with? Link to comment Share on other sites More sharing options...
Infosecdad Posted August 21, 2017 Share Posted August 21, 2017 Might want to mention year, model, engine of your car; that will help. Link to comment Share on other sites More sharing options...
FrankNature Posted August 21, 2017 Author Share Posted August 21, 2017 Might want to mention year, model, engine of your car; that will help. 2005 Outback 2.5L SOHC Link to comment Share on other sites More sharing options...
MilesA Posted August 21, 2017 Share Posted August 21, 2017 Standard spark plugs are NGK FR5AP-11 Platinum. Spark plug gap is set between 1.0 - 1.1 mm (0.039 - 0.043 in). Should you change the spark plug wires? Sometimes, it's better to change just one thing at a time so if there are problems they are easier to diagnose. You can change the spark plug wires later on if you want. It's not a bad idea to change them as preventative maintenance, but not strictly necessary unless they are bad. if you have a multi-meter you can test them. If you change the spark plug wires, either the Subaru OEM or the NGK blue ones seem to work best. Link to comment Share on other sites More sharing options...
