Nighthowl6 Posted August 19, 2017 Share Posted August 19, 2017 Hey all, I need to upgrade my exhaust and looking at the TurboXS mid pipe and y-pipe here is link http://turboxs.com/shop/product.php?id_product=370 and the Nameless Performance Axleback link: https://shop.namelessperformance.com/axleback-exhaust-2005-2009-legacy-gt-25i/ will these two work at replacing the up to the downpipe? Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2017 Share Posted August 19, 2017 Do you realize that is going to be very loud if you have a 3" downpipe. I currently have a Pro Lab Tuning exhaust which is basically the same as both those items and it was only about $260. The Pro Lab has straight through mufflers, and open mid pipe. That exhaust on my 09 Spec B with a catted dp was to loud, you could not talk to someone in the car on the highway. So I kept the midpipe and Y pipe on the Spec and put the stock mufflers back on, nice and quiet, with a little rumble at idle. I took those mufflers and put them on the stock mid pipe on catless 3" dp on my 05 wagon, it is to loud on the highway. Does have a real deep tone. A couple weeks back I put a Invidia Q300 exhaust on the wagon, it was to loud on the highway. It only has about 1000 miles on it and is now in the shed. But answer your question, yes, both those items you linked will work together, but its a lot of money. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08SpecB_DE Posted August 19, 2017 Share Posted August 19, 2017 MagnaFlow makes a nice cat-back set-up. Good rumble driving around but not obnoxious. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2017 Share Posted August 19, 2017 For the OP, http://legacygt.com/forums/showthread.php/q300-vs-hks-silent-hi-power-263708.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2017 Share Posted August 19, 2017 OP, I sold these a few years back, I think they cost about $100 to have a shop make them up. http://i185.photobucket.com/albums/x40/92Si/DSCN7108_zps0qpbx46x.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nighthowl6 Posted August 20, 2017 Author Share Posted August 20, 2017 Thanks for the replies guys, I ended up going with the Invidia Q300, hadn't considered how loud a muffler delete would actually be! Once I see what it sounds like with the Invidia, a downpipe will probably be next on the list. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 20, 2017 Share Posted August 20, 2017 Get a catted dp when it comes time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
