VespaGTS Posted August 19, 2017 Share Posted August 19, 2017 Hi guys, After searching online for a solution I figured it all out. I had to remove the battery to install a new turn signal bulb. After everything went back together I had no power in the car except the horn worked and hazard lights. A big mistake can happen when you disconnect or connect your battery. Always remember to remove the positive lead from the battery prior to the ground. Also when reinstalling the battery hook up the ground wire first and then the positive lead. This mistake blew the main fuse and killed almost all power to the car. What made it confusing was that I still had hazard lights and a horn. It was a $28 fuse but now I am back on the road. Link to comment Share on other sites More sharing options...
sunny5280 Posted August 19, 2017 Share Posted August 19, 2017 Hi guys, After searching online for a solution I figured it all out. I had to remove the battery to install a new turn signal bulb. After everything went back together I had no power in the car except the horn worked and hazard lights. A big mistake can happen when you disconnect or connect your battery. Always remember to remove the positive lead from the battery prior to the ground. Also when reinstalling the battery hook up the ground wire first and then the positive lead. This mistake blew the main fuse and killed almost all power to the car. What made it confusing was that I still had hazard lights and a horn. It was a $28 fuse but now I am back on the road. Always remove the ground connection first and reattach it last. This is to prevent accidently shorting the wrench against the chassis when removing the positive connection. Link to comment Share on other sites More sharing options...
VespaGTS Posted August 19, 2017 Author Share Posted August 19, 2017 The Subaru dealer said otherwise. I agree with you totally and was surprised at my result. He told me if you hook up positive first it tries to ground through all the other chassis connections and blows the fuse. So is this a load of crap? Link to comment Share on other sites More sharing options...
Infosecdad Posted August 19, 2017 Share Posted August 19, 2017 Strange, that's the opposite of what I've known for 30 yrs. I've removed ground first and never had a problem for that time. http://www.popularmechanics.com/cars/how-to/a1454/4213127/ Might want to tell him that he has it backwards, all throughout the subaru FSM you'll find "Disconnect the ground cable from the battery". It never says, "Disconnect the positive cable from the battery" unless it is after the ground cable. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 19, 2017 Share Posted August 19, 2017 Remove ground first-put ground on last. Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted August 19, 2017 Share Posted August 19, 2017 ^^^ this 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
sunny5280 Posted August 19, 2017 Share Posted August 19, 2017 The Subaru dealer said otherwise. I agree with you totally and was surprised at my result. He told me if you hook up positive first it tries to ground through all the other chassis connections and blows the fuse. So is this a load of crap? Yes, it is a load of crap. If the ground is not connected there is no return path through the chassis. Or at least there shouldn't be Link to comment Share on other sites More sharing options...
ehsnils Posted August 19, 2017 Share Posted August 19, 2017 Aside from the risk of shorting the positive side to ground order doesn't really matter. Link to comment Share on other sites More sharing options...
VespaGTS Posted August 19, 2017 Author Share Posted August 19, 2017 Got to love it. Link to comment Share on other sites More sharing options...
